Finally got an Engine Mod!!
Actually it came out and went back in rather easy.
Basically I removed the passenger side from fender well, the plastic fender well, and mostly just the front part, then just removed the 2 bolts that is holding the intake tube to the body or the outside wall of the engine well, and then it just pulled right out. I then just cut the diaper off and pulled the top cap off, put it back in place and put the bolts back on it, sealed back up the fender well and it worked fine. Shouldn't take more than 30 mins.
Of course it's easier if the car is jacked up so the passenger tire hangs down a little to give more work area.
cold air is the next mod and i can tell my car is faster. not sure if its from removing the pieces or the chip but its definately faster.
And the pics that one person posted is correct. those are the parts my brother removed.
