First Custom Road tune on the E16!
Old 02-26-2008, 08:33 PM
  #126
TPRMcfly's Avatar
can't wait for the dyno i prob might go all motor with n20 for awile haha
raise rev limit to 7k
speed limiter GONE!
32 injectors
more aggressive cams
wonder higher comp pistons do any good???? or would going lower be better with n20...id like to be able to run a 100shot safely if possible
Old 02-26-2008, 08:35 PM
  #127
NWAE Cobalt's Avatar
ya...speed limiter gone is GREAT
Old 02-26-2008, 08:37 PM
  #128
XM15's Avatar
Originally Posted by tru2nrtt777
I am wondering about stage 3's... If they claim to be 19-23hp(realistically 15-19) it may jump another 10 hp or so...
8K redline is pretty high though. What is the max for the L61 valvetrain?
Old 02-26-2008, 08:43 PM
  #129
Cobalt4Life's Avatar
build book says over 7k and the valve springs can go, but 7500k is when valve train needs changed.. Id change them if your going to rev past 7k or so..
Old 02-26-2008, 09:02 PM
  #130
shortyhend2004's Avatar
90% of you have no idea what this means lol, yes its tuning but 95% of the stuff you want "tuned" isnt needed and will prolly hurt your mileage/ performance. You DO NOT NEED BIGGER INJECTORS, unless you have boost. Without boost its nearly impossible to overrun them, you will be running rich and wasting gas getting bigger injectors. Also the raising the rev limiter wont do a whole lot til you find out where your power drops. If i remeber peak hp and tq. is at like 5500-6000. So running it to 7k is basically pointless
Old 02-26-2008, 09:14 PM
  #131
brandon2.2's Avatar
unless you upgrade to an aftermarket cam and valvetrain
Old 02-26-2008, 09:19 PM
  #132
XM15's Avatar
I agree, it would be pointless to take it that high with everything else stock. I'm talking about changing the cams though. That should be a nice addition.
Old 02-26-2008, 10:27 PM
  #133
tru2nrtt777's Avatar
Stock valvetrain is good to 7500 but I wouldnt take it past 7 I would get a new one though since I would already be camming, surface the heads to raise the compression ratio, see about boring over and how big pistons i can fit confortably on 91 octane...
Old 02-26-2008, 10:28 PM
  #134
umrdyldo's Avatar
But he 2.4 Mani takes the power curve up so if you take it another bit to say like 6800RPM then the next gear would be in the power band even better
Old 02-26-2008, 10:29 PM
  #135
madmark's Avatar
******* **** ass hole!
it happens after i give up on the car and start selling ****...
Old 02-26-2008, 10:35 PM
  #136
mrsilent13's Avatar
no faith
Old 02-26-2008, 11:02 PM
  #137
Kwin's Avatar
patience
Old 02-26-2008, 11:27 PM
  #138
Delta2.2's Avatar
truth, but if u got cams maybe it would be a nice upgrade for injectors.
and ya doi built valvetrain +cams and ya its logical.
Originally Posted by mrsilent13
no faith
lol
Originally Posted by Kwin
patience
truth
better luck next time
this is not tested or proven to any degree
dont spam crap information. its very skeptical about where that is. wait for some dyno numbers in that range of rpm then we will talk
Old 02-26-2008, 11:37 PM
  #139
kkanowitz's Avatar
Looking towards the other end of this, I read that Vince is planning on building a program for the automatic TCM's, also... I'm running shiftplus right now, but tuning the tranny would give a way bigger benefit, right? Should I maybe look into a higher stall torque converter?
Oh yea....I was also wondering about that ridiculous form of "traction control" that the base-base models have; you know, how it cuts the throttle, forcing the driver to re-apply the gas.
Old 02-26-2008, 11:38 PM
  #140
Speed Mafia's Avatar
Originally Posted by Sw4y1313
Hard to tell honestly. But i'd say its enough to be worth it. We will see dyno info soon.
if we are talking about tuning on stock ecm with mods...you can expect 10-30whp!
GM always tunes on the rich side because they know people will not run 91 octane or higher so they run them rich...timing is pretty on spec i mean you can add 1-2 degrees and thats it but i have personally tuned GTO's and seen 30-40whp just by pulling fuel out and adding a little timing....
so on these cars i believe there is allot of untapped hp!
i personally have been doing tuning with the SMT6 on my ion and just by pulling fuel and adding a little timing the car woke the f up and she runs great and then ofcourse i had to slap on 5psi for fun and now i am adding fuel via 5th injector and timing from the smt6...
so i believe there is allot of untapped hp waiting and now that it seems there is tuning it should be fun!!!!
duane get your turbalt running and get it over to Denver so we can test his software on your car bro!
Old 02-27-2008, 01:41 AM
  #141
Sw4y1313's Avatar
You know it buddy. All the parts are in except the clutch. buying that this week and as soon as i get back, im taking some vaca. to finish it up along with the first weekend im back(weekend of 4/5). Gonna be nasty bro. Give me a call anywhere between 9am and 3pm pacific asap =P
Old 02-27-2008, 12:16 PM
  #142
Wow dont post unless you have facts i have seen a few eco- cavalier tuned dynos. 10hp is about all you will get with I/H/E. Thats getting lucky too. This isnt a tune to pick up tons of power. You will barely benfit from this unless you have more that I/H/E.
Old 02-27-2008, 12:35 PM
  #143
frosty's Avatar
aem fic ftw/
Old 02-27-2008, 12:47 PM
  #144
umrdyldo's Avatar
but power isn't the only factor. no PE delay. no speed limiter. possible rev limiter cutout. in dash shift light
it's not just the 5hp up top that we stand to gain.
Old 02-27-2008, 12:54 PM
  #145
Well 99% of people want bigger injectors and power, both of those you wont need or get. Injectors should be the last thing you worry about and power wont be much.
Old 02-27-2008, 01:18 PM
  #146
Sw4y1313's Avatar
Ok dude, your about half kevins age. you think you have more knowledge about cars then him? hes not saying its gonna open 20+whp, but with full bolt ons(2.4 Intake, Full header-back exhuast) you will see some nice gains, but thats most likely going to be average, not peak.
60lb injectors are going to be a tad small for me, but ill try em first on some lower boost =P
Old 02-27-2008, 01:19 PM
  #147
Rent me! per hour
Area47's Avatar
60lbers are going to be too small?
they support over 400 to the tire on the lsj. where do you come up with this logic?
Old 02-27-2008, 01:24 PM
  #148
Sw4y1313's Avatar
I havent seen one LSJ go over 400whp on here except the mysterious Rebel turbo car. And from what i've seen on pauls, he was pushing the 60's close to the edge and he wasnt even scratching 400whp. I'd also like to not run over 80% IDC, and with that being said, you need roughly 70lb injectors to do that at 400whp. Im just tryin to be safe. And i've done my homework, many many times.
Old 02-27-2008, 01:28 PM
  #149
Rent me! per hour
Area47's Avatar
06black has been the closest to 400. id bet money that in a matter of a couple weeks he will be over that mark.
with 60's.
  #150
Im not saying I know more than him but I have seen the dyno sheets, with rk header, dp, catback, intake there will be no NICE GAINS. Kevin must be old too.
Quick Reply: First Custom Road tune on the E16!
