First Custom Road tune on the E16!
#151
Thats cool and I hope he does. But ill be making sure im not pushing them over 80%. And on paper they go way over 80% at 400hp. I know paper isnt exact, but its a great starting point for safe measure.
#153
It's funny how just about every thread always becomes a pissing match.
I am more interested in hearing about laptop connectvity to the car. I thought I heard that mentioned perhaps? I would like more details if possible.
#154
IMHO, you shouldnt raise rev limit or governor or not much of anything really, unless your either built bottom end, or built with f/i
injectors are important when going F/I from N/A or on an SS, getting a smaller pulley.
#155
I havent seen one LSJ go over 400whp on here except the mysterious Rebel turbo car. And from what i've seen on pauls, he was pushing the 60's close to the edge and he wasnt even scratching 400whp. I'd also like to not run over 80% IDC, and with that being said, you need roughly 70lb injectors to do that at 400whp. Im just tryin to be safe. And i've done my homework, many many times.
the guys who want injectors should look no further than stock ss/sc injectors for NA application. the main thing with them is that you have more control over the same amount of fuel making it easier to run the injectors and u have a more versitile IDC if u want to add more for a later application.
its all about how you tune ur car that determines lots of these factors. i can safely say 06black knows his tunes very well and is reputable.
i know him via our car club website seecarclub.net that we are both on locally. ive seen his setup and its ridiculous.
#158
aren't 2.4 injectors the same as 2.2? IIRC those guys are taking the motors up to 7K on stock injectors so we should be good to go N/A wise on injectors based on that.
I know Cavi Eco guys upgrade to 32# injectors though when increasing the rev limiter but I don't know if their cam selection will have an effect on their IDCs.
#159
Looking towards the other end of this, I read that Vince is planning on building a program for the automatic TCM's, also... I'm running shiftplus right now, but tuning the tranny would give a way bigger benefit, right? Should I maybe look into a higher stall torque converter?
Oh yea....I was also wondering about that ridiculous form of "traction control" that the base-base models have; you know, how it cuts the throttle, forcing the driver to re-apply the gas.
#161
#165
#170
It's smaller than it looks plus they're at an angle....it does replace the stock manifold so there is enough room
#171
i just dont see the point in that thing..
And no!! there is no dyno yet!! I WILL UPDATE YOU ALL WHEN I DO!!!
#172
#173
nope, we can tune for the air coming in, and you can upgrade the injectors if you want...i personally want my air CLEAN as it comes in...and there is just no point on a daily driver or even moderatly moded track/ street car...if it was track only and you were trying to go n/a...AND you had already done everything else you can...then sure...but for most of us...its just a waste of money...
#174
#175
Second...not all of us are jumping the boosted banwagon...some of us would rather "waste" our money building muscle w/ metal like over boring and a high comp motor. It doesn't have the sound of a spool or the sound of a BOV....but it does work and is more of a challenge. So dont knock on ITB's....
Are you saying this tune is only for those going boosted or something? You do know there is life BEYOND boost right?
