First Turbo Sedan 2.2L - PICS and VIDS
Old 10-24-2011, 08:01 AM
  #151
flyy's Avatar
If i remember from other builds, you can pull the motor out from the front of the car.
Oh holy **** yeah that's was I was hoping for. That would be so much easier to do
You have any links to any cobalts that have done that? or know anybody that's done it.
Old 10-24-2011, 11:30 AM
  #152
Tundraboarder666's Avatar
me. lol
Old 10-25-2011, 07:15 AM
  #153
flyy's Avatar
Originally Posted by Tundraboarder666
me. lol
so how was it done? is there just a bar you unbolt and roll the engine out from the front of the car? is the suspension and wheels still hooked up when that's done or what?
Old 04-19-2012, 10:18 AM
  #154
2009CobaltLT's Avatar
Quick question, where did you hook up your sensor for your boost gauge?
Old 11-09-2012, 12:42 PM
  #155
mkulrey13's Avatar
Bump because i miss my 2.2L
Old 11-09-2012, 05:50 PM
  #156
nhanson's Avatar
I love mine. What was the most whp you saw?
Old 11-12-2012, 08:12 AM
  #157
mkulrey13's Avatar
249whp 254wtq
Old 02-14-2013, 03:41 PM
  #158
andrewcarr1993's Avatar
I know this is a thread revival but does Hahn still even sell a 2.2 turbo kit?
Old 02-14-2013, 05:22 PM
  #159
I think Hahn might still sell one, but IIRC they basically just put their name on the kit and didn't actually make it themselves. I know you can still find this exact kit online for way too much $$$.
Old 02-15-2013, 12:04 AM
  #160
PsychoCam's Avatar
Hahn revised the oil feed and oil drain on the original Garrett alpha kit. Then they sold it as their kit.
The whole kit is all Garrett made. I have the original Garrett alpha kit. Has the better oil and drain line set ups.
The Hahn kit used their POS quick disconnect oil drain hose to the oil drain plug. And their feed line was tap'd into the side of the water pump housing area.
The Garrett kit used the factory boss location on the back of the block for the oil drain (I had to drill a massively large hole in my block lol. Seemed so scary at first but it actually drains right into the motor above the pan). So it is higher than the drain plug. Also the feed line is in the back of motor by the header. Used an oil galley plug.
IMO the alpha oil setup is way better. I have had my kit for like 4.5 yrs now and not 1 problem.
Sorry That was kind of a rant just throwing out the info. The Zzp kit is so much cheaper and is just as top notch quality.
Old 02-15-2013, 10:49 AM
  #161
mkulrey13's Avatar
If was i was to do it again... Id go garrett alpha again.
Old 02-15-2013, 03:31 PM
  #162
I knew there was a small difference between the two, This would mean that I have the Hahn kit then too. I bought mine used for cheap hehe. And yeah scary part is drilling that hole in the block... So nervous doing that.
Supercharged06SS
12-11-2022 04:47 PM
dennis69
10-20-2015 04:49 PM
10-13-2015 09:32 PM
maliki778
10-01-2015 07:39 PM
SSLOW06
10-01-2015 07:21 PM
Quick Reply: First Turbo Sedan 2.2L - PICS and VIDS
