free 2.2!!!!
free 2.2!!!!
[URL="http://www.gmpartsdirect.com/results.cfm?perfPackages=1&pkgid=26"]
http://www.gmpartsdirect.com/results...ges=1&pkgid=26
Original Hayden Fanatic
DESCRIPTION: Ecotec 2.2L
See new part number 19156263 for pricing.
Ecotec 2.2L Production Engine
This 4 cylinder Crate Engine (RPO L61) has the following features:
DOHC with Sequential Fuel Injection
Bore is 86.00 mm and Stroke is 94.60 mm with 10:1 compression ratio 140 Horsepower @ 5600 RPM and 150 lb-ft @ 4000 RPM torque This engine powers the current Saturn Ion, Chevrolet Cavalier, Pontiac Sunfire and Grand Am, Oldsmobile Alero, and Chevrolet Malibu This production engine includes: exhaust manifold, intake manifolds, injectors, fuel rail, balancer and water pump
Technical Notes: Pulley, belt, p/s pump, a/c pump, starter, alternator, and engine cover, are not included with this engine
Taken gfrom the page.....
there is also a * by the part number, meaning read the fine print.
* This part has been replaced by a new part number. The new part number will be used if you add this part to your cart.
If you really want a free 2.2L, go to Jiffy lube and have them change your oil, then hurry up and go home and cross thread your oil drain plug, and drive around. Then say the wanker who changed your oil cross threaded the drain plug, and caused your engine to lose oil, and blow your motor.....
x2
You don't have to do it on purpose. They screw it up on their own.
