ful bolt-ons and tune
#76
Yes the dyno jets read really high. Most quote a 7% difference over a mustang dyno.
I have a 2007 cobalt ss sc and they dyno stock at about 214whp. I have a 3" cat back an injen c/a and I dynoed a 231 on the mustang dyno. On a dyno jet I post in the 240's which is way off.
Like he posted, if he uses it as a starting point and always runs on dynojets he will be ok but if you switch dont be suprised if you post more realistic numbers.....
Here is the videos and slips of mine - http://www.cardomain.com/ride/3356945
#78
none yet... but i did grab a sway bar for cheap lol. i promise as soon as i have the time a money to install everything, tune, and redyno the results will be here!
#80
unfortunately no, not yet. i am saving my money, hoping to be able to get tuned here in the near future... as soon as i can tune ill redyno and post results. sorry its kinda a slow process lol
#81
yo, i know its been a LONG time sense i had an update, but here i am will a small amount of progress.
1st off let me say this... if you are an 08 2.2, if you dont want a big hassel, stay away from the 2.4 intake manifold. the bolts match up, but my brake booster line was in a different place and i had to get a custom hose cut for it. second the map sensors are different. the nipple into the mani and the harness are both totally different, so again i had to get a new harness and rewire that. if you are willing to do the work though, the gains in the top end make it worth it
that said this is the ONLY part i have had a chance to get on. school and work are killing me right now. i did however find that under 3.5k rpms i am looking at about a 2-3MPG gain in fuel economy! yes better gas mileage! at 3.5k-4k rpms i FEEL rougly 12-15hp gains and maybe 5-7 ft/lb torque... this is all rough guess, i have not dyno'd yet.
i have a guy working me up a price to bore out the LSJ exhaust mani i have, and then i will most likely be going with a 2.5" DP instead of this lsj dp i have now. i am looking at a pigtail on ebay so i dont have to repin my tb harness, and will be buying that shortly, once i have the exhaust all figured out and worked up that is. once that is in my hand i will be getting my tune and then i will redyno and post the new logs.
on a side note, i will be picking up some eibach sportline drop springs tomorrow and maybe a Hurst STS. but that will be determined when i get to the Modern Performance storefront.
more updates as the build progresses! thanks for following!
p.s. i say some dyno sheets for other cobalts with similar mods, and 140hp is a normal rating, my TQ however was a bit low, but that could have been my intake slowing airflow. we will see though
#82
Nice to see some progress being made though, I forgot about this thread!
#83
i didnt want to drill out the hole for a couple reasons, 1 shavings in there could have been a pain to get out, and if i had gone too big i would have been screwed lol. as far as the brake booster hose, i completely forgot the 2.4 would have needed a hose to reach that far.. i feel like a ******* now lol.
also, ill get before and after pics for the springs to give people a ood idea of the drop on an LT
#86
another update! things are moving soo much faster now that im single LMFAO!!!!!! got in a pigtail harness for the throttle body, now i need to talk to a guy about a tune... here is where the advice comes in... HP or trifecta...
#88
Just an FYI I went to get HP tuned and even though its supposed to work with the 07 and up 2.2's it didnt. And i went to nick (BYT) so im sure he knew what he was doing. I just got a trifecta tune
#89
i actually am going though a local HP guy. he has done alot of cobalts, 05-08 2.2's, lap's, lsj's and lnf's. he is an incredible tuner as everyone tells me, and cheaper then trifecta lol
#90
UPDATE! i just wanted everyone following this thread to know that i have ordered a new catless dp/header combo, and will be getting my tune in the next couple weeks so i can run my 2.4 intake manifold. i did get the sportline springs installed, and they look great! i have before and after pix (see below). i also have a cosmo racing STS incoming as well.
over all
front drop
rear drop
stay tuned for more info! things should progress quickly now!!!
over all
front drop
rear drop
