GHOSTS build thread
#51
here is where i stand on this.
the block is currently with golden eagle getting sleeved with their hd sleeves.
the head is still in san antonio with marty, he ran into a small problem with the supertech seats coming loose once they heat test everything, so he had to order a few more.
the car is now having to switch to a cable driven t.b. for the fast system to work and ill need the msd dis-2 ignition control along with the 2 blaster coil boxes for the ignition set up
o and here is a fun interesting fact that alot of people are probably going to flame me on.
a skunk2 fuek rail for the k20 honda engine works on a ecotec motor.
yup we test fitted it and the holes for the injectors line up correctly. its actually easier to run a return style system using it, which i am doing.
#52
Sure you're not putting too much stress on the injectors ?
bore center of the K20 is 94mm, and 95.8mm on the ecotec, so the injectors center should be almost the same
should line up "correctly", but not perfectly
Btw, any more info about the golden eagle sleeves ? first time I hear about it for our engines ?
#53
well they dont get into too many specifics on the engine, they actually spell it wrong ECOTEK lol
but they have us listed as a saturn motor because they did alot of work with lisa kubo's ecotec drag car.
#63
ok here is a current update
parts:
short block:
wiseco pistons 8.9:1 compression ovr szd
Pauter connecting rods
Clevite rod bearings
Eagle Crankshaft
GM main bearings
OTTP main studs
Golden Eagle Sleeves
ATI crank dampner pulley
Assembled and balanced by Watts Racing engines via T1 Race Development
Head work:
SCE Exhaust Gasket
COmetic Head Gasket
ARP head studs
Level Zero Motorsports Balance Shaft Delete Kit
Bates Oil Pump Gears
ZZP Phenolic Intake Spacer
Supertech 78lb valve springs
Supertech 0.5mm valves
supertech retainers and seats
All ecotec bronze valve guides
GM adjustable cam gears
Comp Cams turbo grind cam shafts (with cam sensor put on)
Head assembled and ported by Marty Ladwig Racing via Jotech Motorsports
Turbo:
Turbo Manifold by Full Race via T1 race development
Tial V60 wastegate
HKS blow off valve
SPearco Intercooler
Garrett GT35R ball bearing turbo T4
Hahn Intake Manifold
Fuel system:
Injector Dynamics 1000cc high impediance injectors via T1 race development
Walbro 255 fuel pump
bosch 044 fuel pump
kn oil filter
transmission:
Exedy light flywheel
hopefully ill be doing some mock ups next week for u guys
parts:
short block:
Eagle Crankshaft
GM main bearings
OTTP main studs
Head work:
SCE Exhaust Gasket
COmetic Head Gasket
ARP head studs
Turbo:
Tial V60 wastegate
HKS blow off valve
SPearco Intercooler
Fuel system:
bosch 044 fuel pump
kn oil filter
transmission:
#65
well i am waiting on the delete kit to come in, they are shipping out today.
the short block is scheduled to be done by the end of this week, and then we are going to start doing some mock ups. Im having a custom fuel rail made for $250 and i am going to be making block off plates for the electric water pump. Does anybody happen to know the part number or have 2 of those spacers that attach the fuel injector to the cylinder head? some how i am missing 2
#68
They can be anything past .030 and they became extra weak I have found this out the hard way since my block has been bored twice at .020" your fine after that geats hairy. Sleeved is the best way.
#72
hey somebody actually remebered my build lol
right now i am having my new ignition system and harness made.
im running the M&W pro 14 kit with honda cbr coils ill have pics for u guys next week
oh and im selling my GT35r turbo that has been sitting in the box brand new for 2 yrs
