GMP Intake Manifold
Originally Posted by Stealth06LT
I was planning on picking one up now that im trying to piece together a turbo kit. If I can get it dirt cheap from service or even free then its a worthy investment of time, I wont put it on until my turbo setup is ready. I want a turbo but im still not sure wat size injectors and turbo to get. I was thinking a GT28RS, or GT3071R. THe injectors im lost with.
Ball Bearing...that's up to you.
Injector sizing depends on how much power you're aiming for. What are you aiming for? Also, you'll need some type of adjustable fuel pressure regulator to turn down the fuel pressure so you don't flood your motor or cause "sputtering" with bigger injectors.
You think a custom log-type one would be cheap to make, I mean I have a friend with a TIG welder and a ton of tools. Theyre a metal supply depot right by our dorms. I dunno if custom would be crazy expensive or not.
I was hoping 300hp + when its all said and done, anything after 350hp would be amazing if possible. The GT28RS only holds up to 350 from what I've heard, I want to make enough power without maxing out the turbo. I;d like to run several boost levels with a digital boost controller, but probably no more than 16psi. I was thinking 50lb injectors would be good for those levels, but im sure im wrong,lol.
Also, you don't want to just shoot to 16 PSI, you want to start small and aim higher.
Are these turbos internally or externally wastegated?
How are you going for fuel management?
My biggest problem is the auto trans, I was hoping there would be some way I could find a wrecked 5spd cobalt at the junkyard and buy the tranny. I have a few hook ups back in FL, im back home in NY now, but once I get down to FL for school in August the build is going to begin.
Originally Posted by TexasPhil
HP Tuners software. enough said
Originally Posted by slowion2
milk NJHK for all his knowledge, he's got the right info for what you're looking to do
the 28rs is going to spool pretty damn quick, you sure you want that?
Yeah, BB Turbos seem kind of fast spooling for me...if I was running a lower compressioned motor where I'm more dependant on forced induction to make power even under less engine load, I'd get it.
Originally Posted by NJHK
I'd say get 360 CC injectors initially but get an adjustable FPR cause that will cause idling issues, even possibly flooding of the motor.
http://www.turbobygarrett.com/turbob...rs.html#medium
#36
I was goign to make that the max I aim for once im done, 8lbs is enough to begin with. I think the GT28RS has the wastegate built onto the turbo, I believe the GT3071R is the same way, someone correct me if im wrong. Doesn't Aeromotive make fuel pressure regulators that will work with the Ecotec's or what other companies are out there? Heres the link to Garretts site if you want to clarify anything for me
Yes, aeromotive makes one.
What you doing for fuel management?
#37
not sure about fuel management yet, anybody have any suggestions, ( and no soft hands because i type on this damn computer all day,lol) and YES NJHK has all the knowledge, hes the Ecotec Yoda. Yea the GT28 spools quick, Id love to have more midrange than anything but Im worried the GT30 and up series will start to have too much lag on the 2.2L.
#38
I was thinking 8:5:1 pistons(I think Wiseco makes them for the Ecotec) so I can pump up the boost a little higher without having to worry about too high compression. Then theres the issue with rods, I think Crower makes billet rods for our car. I never know whether I shoudl get H-beams or I-beams.
#39
Thank you for the compliment
#40
Go to www.carcustoms.net and you'll find 8.9:1 pistons...that's a low enough compression.
#41
moochass grassyass NJHK. Your welcome on the compliment. I dont know enough about the full capabilities of the Ecotec so its good to get some friendly advice. My names Joe by the way in case the Joe-Balt in my sig didnt give it away. lol)
#42
I'm old school
http://www.gofaststuff.com has the cheapest price I found for the Eagle rods at $309, plus they usually throw in a set Clevite bearing for them for free.
#43
