Gmpp Exhaust
The manifold releases the exhaust(by product of the explosion from your cylinder) through pipes out through your exhaust tip. The other parts, like a DP are ways of breaking down the exhaust system in order to replace specific parts. The DP is connected to the manifold and yes, you HAVE one already, every car does. Hopefully that clears things up a bit.
Its huge.
I bought the straight cut one with mine but didn't end up using it because its too big. It wouldn't be bad on an SS car because they have a different rear bumper, but on a base model the tip is just too big, and it hangs too low to look good.
The SS's use different bumpers, the SS/NA (2.4 non supercharged. NA is naturally aspirated, means it doesn't have a turbo or supercharger) is close to yours, except it has a plastic insert in the middle that extends over the exhaust area. it is about an inch lower than your bumper. The tip fits much better with that style of bumper. The SS/SC (SC is supercharged) has a different bumper, look around and you'll find a lot of pictures, it also hangs down a little lower.
If you already bought the tip try it and see if its your thing. if it is, eh, thats great. (be prepared for a few rice comments) if you haven't bought it, don't.
heres a real good sound of the different exhaust the sound clip is right below the picture. under the drawn out picture.
http://www.crateenginedepot.com/stor...P1379C146.aspx
no problem. I can get some pictures of it if you want to see how it looks. it will take me about a week to get to my parents house where i have the tip at but i can take a pic next time i'm there with it on. if you want.
