GMPP Intake
Old 12-22-2006, 05:10 PM
  #51
nramlow2006's Avatar
holy **** ur 2.2l engine looks way different.. wow i dont like it...
Old 12-22-2006, 07:16 PM
  #52
Brraaapp's Avatar
Thanks dick!! Jk. what does yours look like?
Old 12-22-2006, 10:48 PM
  #53
BlueThunder2006's Avatar
He's referring to your valve cover. Your '07 has coil-on-plug ignition, which the '05 and '06 2.2's don't have. Yours looks more like the 2.4 valve cover. Ours has a cover over the center portion between the cams, so you can't see the plugs and plug wires.
Old 12-23-2006, 07:28 PM
  #54
LewiSS's Avatar
On my 2.4, I've been thinking about making a cover that raises up high enough to clear the coils and then back over the coils, leaving it open in the back for the wiring. That would visually hide most of the clutter. I'll use aluminum sheet and give it a brush finish (easy to fabricate compared to stainless).
Old 12-24-2006, 03:51 PM
  #55
Brraaapp's Avatar
Yeah I should prolly fab something up. Just to clean it up a little, so it dont look so messed up.
Old 01-17-2007, 01:29 PM
  #56
hardtocope's Avatar
how are the intakes holding up? any CEL?
Old 01-17-2007, 07:43 PM
  #57
Blankobalt06's Avatar
Originally Posted by rallyyellow06
The thing I've noticed about the GMPP filter element is its still a crappy styled filter. Just a gausey paper element filter, I think GMPP could have done better.
Halfcent I believe the 07's don't have SAI because of the new ignition system.
GREAT!!! I'm going to trade mine in for a 07. I'm so friggen pissed. WHY???
Old 01-17-2007, 11:37 PM
  #58
Red07SSNA's Avatar
I've had my GMPP Intake on since they became available in September and have not had any problems......well....probably less MPG....'cause I like to hear it
Old 01-18-2007, 04:36 PM
  #59
MOTORSPORT03's Avatar
Originally Posted by LSCobaltlover05
Well i just installed mine and i am also having the hood problem... what did u do to fix it cause mine really sits up high on the passenger side and low on the driver side... the sealer is pressed down as far as i can press it... what do i do?
CAN YOU JUST DO AWAY WITH THE BOX AND JUST HAVE THE INTAKE THERE?
Old 01-18-2007, 06:40 PM
  #60
Red07SSNA's Avatar
There are no brackets or supports to hold it in place without the box. I'm sure with some "backyard" engineering someone could come up with a fix.
Old 01-18-2007, 08:27 PM
  #61
hardtocope's Avatar
can the intake be heard a lot more on the outside of the car? or just the inside?
Old 01-19-2007, 12:32 PM
  #62
Brraaapp's Avatar
its louder outside the car. It sounds pissed off!!
Old 01-19-2007, 01:55 PM
  #63
06Pursuit's Avatar
these cars with intakes sound sooooo mean. I had my buddy drive my car and pass me while i was driving his.....just wow. they sound sooo good
Old 01-19-2007, 02:49 PM
  #64
im planningon getting this intake for my car... then my next envestment is the hood that comes with a scoop that will work with the short ram.....
i cant remember who makes it though
Old 01-19-2007, 09:14 PM
  #65
hardtocope's Avatar
will my car pass inspection in new york with the gmpp intake?
Old 01-20-2007, 02:23 PM
  #66
Red07SSNA's Avatar
It is 50-state emissions approved -- just put the CARB decal (comes with the intake) in a visible location. I put mine on the intake itself.
Old 01-22-2007, 01:03 PM
  #67
Brraaapp's Avatar
yeah I just left my emisions sticker in the glove box.
Old 01-29-2007, 01:46 AM
  #68
toddsbalt's Avatar
any cel from the gmpp intake?
Old 01-29-2007, 10:56 AM
  #69
LewiSS's Avatar
Never on mine. It works perfectly, no problems.
Old 01-29-2007, 11:23 AM
  #70
Red07SSNA's Avatar
Mine neither -- no CELs yet.
Old 01-31-2007, 05:41 PM
  #71
hardtocope's Avatar
what year cobalt is yours?
Old 01-31-2007, 05:51 PM
  #72
Delta2.2's Avatar
do you think an Injen is better or equal to a GMPP intake?? like i know the gains of the Injen with a GMPP exhaust connected was a 7whp gain. do you think the GMPP intake does the same?
Old 01-31-2007, 06:42 PM
  #73
Red07SSNA's Avatar
2006.
Old 01-31-2007, 06:56 PM
  #74
hardtocope's Avatar
2006.
does our car have secondary air injection?
Old 02-01-2007, 09:47 AM
  #75
Red07SSNA's Avatar
No, my Cobalt did not come with SAI.
Quick Reply: GMPP Intake
