Going boostin
Going boostin
Ok so im going turbo. im doing the garret tuner kit catback and tune. isnt that all i need to do a basic setup. i amd going to do motor and tranny mounts and more stability stuff later but shouldnt y setup be fine with a catback and tune?
Also the tuner kit does not come with injectors or a boost gauge so he has to add that to the list
We should also mention that it's recommended that a turbo 2.2L. go to a dyno with the Trifecta Handheld PDA for tuning.
If he's installing this himself then this is what I would recommend you have ready before you even start turning wrenches
- GT Tuner Kit
- Clutch (I'd say Stg.2 or 3) << This can wait as long as you drive it normally and don't trash it
- 2.5" or 3" downpipe
- 2.5" or 3" catback
- Trifecta tune
- Boost Gauge
- Wideband
- Injectors
- ZZP Injector Harness
- 5 quarts Royal Purple 5w40
- K&N Highflow Oil Filter
- 4L. Preston Dex-Cool
After your done with the install I would also recommend.
- 3 Gauge A-Pillar
- Oil Pressure Gauge
- Oil Temperature Gauge
- Turbo Timer
- 40 Amp Bosch relay to power all you new accesories
I kept popping a fuse when I had too many gauges running and the Relay fixed that problem.
Looking at $5000 for all this
At CSS.Net we take pride in our ability to scare people who post treads like "I'm going FI" or "I'm going custom turbo"
Just kiddin
Boostin15
How to Guide
12
05-29-2013 05:23 PM
