Good news for us 2.2's
#76
depends on the size of injector you go to... the 2.2 computer maxes out at 52lb injectors and takes a complete re-tune if you want to upgrade to 60lbs to adjust the AFR. Say like he commands the computer to run a 12.2 AFR but the computer will only see 52lb rate and the 60's will let extra fuel flow un-detected.... in turn the AFR gauge will read out something like 11.4 or so. When Vince had my computer set to 12 AFR in the computer i was reading 10.9 on the AFR because of the 60's.
#77
#78
#80
#81
You are going to be limited by the ECM's OS eventually, but honestly im not sure what the max injectors you can run on it. Im sure you will be fine because the largest High Impedance injector you can find is a 79lb/hr. Im not sure what that turns out to be in cc/min though. But if your building for power to exceed that kind of fuel, you should be going with a standalone anyways.
#83
WOW WOW WOW...
HP Tuners is good for the 07s now?
sense when? i been talking to eric i think his name is over the summer, and he said most defently not do they have any programs fo rthe 07 2.2 nor will they ever...
#86
i made the post and said and even quoted what i was told from an actual gm racer. the only thing was that he wasnt 100% positive. so we needed a way to verify
#87
yeah...i just checked out the ls2edit page.... http://carputing.tripod.com/index.htm .... and googled it and for the price it seems like a damn good deal...not sure about the support tho..it sounds like its more for the xperienced tweaker....but imma keep looking to see if i can find help for the rest of us noobs
