Good news for us 2.2's
Old 12-28-2008, 01:22 PM
  #76
xCobalt05x's Avatar
depends on the size of injector you go to... the 2.2 computer maxes out at 52lb injectors and takes a complete re-tune if you want to upgrade to 60lbs to adjust the AFR. Say like he commands the computer to run a 12.2 AFR but the computer will only see 52lb rate and the 60's will let extra fuel flow un-detected.... in turn the AFR gauge will read out something like 11.4 or so. When Vince had my computer set to 12 AFR in the computer i was reading 10.9 on the AFR because of the 60's.
Old 12-28-2008, 01:55 PM
  #77
Tank07's Avatar
Originally Posted by 06blackg85ss
I may pick up LS2 edit sometime in the spring sinceit looks like htp won't support it, plus there are some features of ls2 edit that hpt doesn't support
so if you get the ls2 edit will that be able to help me out with putting on a supercharger?
Old 12-29-2008, 01:26 AM
  #78
elecblue06's Avatar
oh really.. didn't know that .. that sucks just another reason 2.2's are teh gay lol sorry couldn't help myself
Old 12-29-2008, 05:55 AM
  #79
Tundraboarder666's Avatar
Originally Posted by FASTL61
well if you get LS2 edit your might have to make a trip to AZ
I second that! lol
Old 12-29-2008, 04:11 PM
  #80
06cobaltindallas's Avatar
ok so are you saying that even with ls2 edit the max injecotr i can use is 60lbs? i ask because for my build i have to use 1000cc
Old 12-29-2008, 09:33 PM
  #81
Sw4y1313's Avatar
You are going to be limited by the ECM's OS eventually, but honestly im not sure what the max injectors you can run on it. Im sure you will be fine because the largest High Impedance injector you can find is a 79lb/hr. Im not sure what that turns out to be in cc/min though. But if your building for power to exceed that kind of fuel, you should be going with a standalone anyways.
Old 12-29-2008, 09:35 PM
  #82
06blackg85ss's Avatar
they said the same about the LSJ PCM, I'm running 79lb/hr off the stock pcm.
Old 12-29-2008, 09:38 PM
  #83
pykie's Avatar
WOW WOW WOW...
HP Tuners is good for the 07s now?
sense when? i been talking to eric i think his name is over the summer, and he said most defently not do they have any programs fo rthe 07 2.2 nor will they ever...
Old 12-29-2008, 10:34 PM
  #84
no hpt isnt working. i talked to the techs today and its a no go.
boo hpt
Old 12-30-2008, 09:28 AM
  #85
pykie's Avatar
then the guy who made this post was lying....
Old 12-30-2008, 04:01 PM
  #86
i made the post and said and even quoted what i was told from an actual gm racer. the only thing was that he wasnt 100% positive. so we needed a way to verify
Old 12-30-2008, 04:53 PM
  #87
ilovecars's Avatar
Originally Posted by constantproject
yeah...i just checked out the ls2edit page.... http://carputing.tripod.com/index.htm .... and googled it and for the price it seems like a damn good deal...not sure about the support tho..it sounds like its more for the xperienced tweaker....but imma keep looking to see if i can find help for the rest of us noobs
lol great sig man
hacadacalopolis
10-28-2015 06:09 PM
Tupp
09-30-2015 08:18 PM
Dylan Johnson
09-30-2015 08:57 AM
09-26-2015 06:44 PM
Quick Reply: Good news for us 2.2's
