Got My Interceptor and have couple questions
Old 08-28-2007, 08:05 PM
  #51
fbaero10's Avatar
im scared to get one now man.. not cool lol.. call the company see whats up with it. also ask about the 2.4 if u can
Old 08-28-2007, 08:08 PM
  #52
wdsoccer's Avatar
will do
  #53
Beck's Avatar
your BCM is probably fuxxored also make sure that your ECU isnt loose
Old 08-28-2007, 08:09 PM
  #54
mcoder77's Avatar
I hope you get it worked out. Let us know what they say.
Old 08-28-2007, 11:29 PM
  #55
wdsoccer's Avatar
well i went to a parkin lot turnd off the car and unpluggd the interceptor from the obdII and then plugd it back in and it works fine again
ok. i went to try it again. this time i was stoppd when i pressed it and the same thing happened. maybe mine has a defect.....im gonna wait to see what aeroforce says
Old 08-29-2007, 01:34 AM
  #56
Coblt ss super's Avatar
how come mine doesnt still turn on with the car?
Old 08-30-2007, 01:47 PM
  #57
mcoder77's Avatar
I was just wondering if you have had anymore problems out of your interceptor yet? Did you contact the vendor and find out the information that you needed?
Old 08-30-2007, 01:51 PM
  #58
heyitsmikey1987's Avatar
i got one on my ss/sc but my shift light on it doesn't work
Old 08-30-2007, 07:12 PM
  #59
wdsoccer's Avatar
yes i have problems with it. i emaild them to see whats up with it. havent got a email response yet. im gonna send another one to make sure they get it.
Old 08-30-2007, 07:32 PM
  #60
mcoder77's Avatar
I hope you get everything worked out. I am really wanting to get one of these for myself but don't want any problems. I already got my stcok ss/sc pillar on the way. Please keep me posted on what you find out.
Thanks
Old 08-30-2007, 08:15 PM
  #61
wdsoccer's Avatar
will do
Old 08-31-2007, 04:33 PM
  #62
mcoder77's Avatar
I take it you still haven't heard anything back from them yet ^
I just got my pillar in today but I'm holding off untill you get everything worked out.
Old 08-31-2007, 06:41 PM
  #63
wdsoccer's Avatar
they havent responded yet. im gonna write another one tonite
Old 09-02-2007, 11:27 AM
  #64
mcoder77's Avatar
I guess there not answering back because of the weekend.
How hard is it to remove and reinstall the pillar? I haven't messed with it yet but it looks like just a couple of clips are holding it in place. Any special technique needed or just pull it off?
Old 09-02-2007, 01:11 PM
  #65
wdsoccer's Avatar
take out the screw im the top. then just pull it. there are clips that just pop out
Old 09-02-2007, 01:14 PM
  #66
mcoder77's Avatar
Kewl, sounds simple enough.
Thanks
Old 09-02-2007, 01:23 PM
  #67
wdsoccer's Avatar
OK, I apologize for this inconvenience but you'll you have to send it back for a re-flash, there is a glitch in the software that wasn't discovered until after your gauge was sent out.
The performance timer uses a very high speed data rate, it may be too fast for your car's data system. We were not aware of this problem but will look into and my need to slow it down on your car. Has the performance timer worked when you've been able to stop the car and start the timer in a shorter period of time?
TQ is only available on automatic transmissions. Don't know what you have but keep that in mind. The 2005/6 2.2/2.4 Cobalts had limited parameters support compared to the 2007 for example. HP should be supported though, are you getting a MAF lb/min reading? This is necessary to get hp.
thats the response from aeroforce.
Old 09-02-2007, 01:52 PM
  #68
mcoder77's Avatar
I have an 07 so I wonder if this would give me less problems? I guess I might wait a month and let them get everything worked out before I order mine.
Thanks for the update.
Old 09-02-2007, 03:47 PM
  #69
wdsoccer's Avatar
NP. he said it just needs a reflash. so you can order one now
Old 09-03-2007, 09:32 AM
  #70
ORT
ORT's Avatar
ohhhhh so that we be why mine was taking so long to get to me. they were most likely reflashing it. or i can just blame you for finding a problem :-P lol
Old 09-04-2007, 11:22 AM
  #71
mcoder77's Avatar
Did you get your gauge back yet? Everthing working OK now?
Old 09-04-2007, 11:26 AM
  #72
wdsoccer's Avatar
lol. i havent sent it off yet. gonna do that tomorrow.
the first email said that it needs a reflash and the second said that they didnt know this. im gonna send it back and see what they say
Old 09-04-2007, 11:38 AM
  #73
SKDR112888's Avatar
I have an 07 SS/SC and I bought the interceptors a long time ago and when I first got them they had some problems like completlly shutting off or they would freeze and they didnt read all the parameters they should have so I contacted Aeroforce and I had to send them back to get reflash/reprogrammed and they have been perfect since!
Old 09-04-2007, 11:51 AM
  #74
wdsoccer's Avatar
thats good ot kno, i hope mine will be fixd
  #75
xravenwingsx's Avatar
i got dual interceptors last year for my 06 SS/SC--hooked the power wires to the OEM boost gauge power wire, and still doesn't work. I think I'm giving up on gauges. :P
Quick Reply: Got My Interceptor and have couple questions
