Guinnae Pig yet Again
Well first i tested the triphase mod and that went ok but i dont recommend the waste of money...now i am going to test a non-moving votex generator for the 2.2...combined w/ the injen cai i should see some small increases in power due to better fuel (atomosation?) or a better burn if you will....so i get it soon and ill let you guys know if it it worth it...only $60 so if i get even 3 hp it's pretty cheap
Dont ever listen to any of those things. All they are are fans that you put in your intake and "blow" air into the engine. But no matter what your TB can only handle so much air. The only good thing about the fans are they blow air through air ducts on race cars to cool brakes...
But in this case...GOOD LUCK
ya this isnt a fan it just spins the air , doesnt increase airflow, giving the fuel more time to mix w/ the air and burn better...but thats what this is all about...i test and you reap the benefits
Yep, Wasted 30 bucks.
See these...
https://www.cobaltss.net/forums/show...ght=Turbonator
https://www.cobaltss.net/forums/lounge-42/turbonator-yay-nay-8744/
See these...
