Hahn Intake Manifold on 2.2
It is either for secondary injectors which would be a pain to wire in or blocking you existing injector holes and allowing more room for the a/f mixture to mix properly.
Thanks guys for the input. Yes I seen the one for port fueler. I think it would be a nice piece for an ecotec. How would it effect performance since the injectors are moved?
You are OVER 400 HP on your 2.2L? What do you have?
We have not saw much of any 2.2L's needing 8 total fuel injectors. Plus like others state it is a pain to connect up to the stock system.
Ours is similar, just stronger and does not blow up
It will ad a couple HP because there is more room for the fuel to mix with the air but not enough to warrant the $199 option. To fully understand research throttle body spacer for old TBI engines.
Quick 1 minute google search...
https://www.cobaltss.net/forums/part...nifold-233781/
http://www.*******************/forum...l=1#post144784
Then just this past week, "Killa SS" PM'd us this:
Cobalt SS Network - View Profile: Killa SS
"I already have a hahn intake that came with my lvl5 turbo kit, and its cracked welds 4 times in the same place. i really am not very happy with them and dont want to deal with that again."
Photos of a few of ours:
https://www.cobaltss.net/forums/part...ls1-tb-262173/
http://www.tristatetuners.com/forum/...&postcount=148
https://www.cobaltss.net/forums/5711732-post18.html
http://www.backyardturbo.com/nick/bl4des/TTR_BYT17.JPG
