Hahn Turbo
#76
yea hopefully it just needs some tuning to get the curve better around the 4.5 mark. We dont really have alot of information on what brand of dyno they were using, what gear it was taken in, amount of tuning done, other mods done to car, etc
#80
Originally Posted by roccityroller
yea, to see if any other mods were used to obtain their 222 whp numbers and what the setup was dyno-wise
#81
Originally Posted by NJHK
When Hahn does their dynos, they do it straight up with just the kit on a fully stock motor.
#82
Originally Posted by biniecki
If that is true than that would explain the retart around 4.5k The system isnt tuned to perfection. With the proper tuning i think the curve will improve
#83
man i cant wait now i gotta figure out how to pay for this stuff now lol
NJHK:
if i get the kit and want more power after i can just upgrade stuff like the turbo and add a boost controler etc i read your write up on custom turbos on your site very informative
NJHK:
#84
NJHK:
NJHK:
That turbo is good for I believe 20 PSI of boost...you have a good amount of room for power on that turbo.
If you really wanted to change the turbo and not change your manifold, you would have to stay with another mitsubishi turbo. If you go on http://www.ryne.com you can see which turbochargers you can upgrade to.
Glad you enjoyed the write up, if you have anymore questions, join the forum and start posting and I'll help you out some more.
#86
ok if its good to 20 psi im sure i wont need a diff turbo thanks for the help
You're welcome.
#88
its on his forum i clicked it from somewhere just click his banner and look around its very indept so its probally a sticky
linkage
http://www.ecotecforum.com/forums/showthread.php?t=35
linkage
#90
1 Post
The pic and writing below is coming directly from Hahn Racecraft. The dyno test was done at 8psi. The 16G turbo is capable of 35psi. Not sure about the Ecotec's capability of handeling 35psi, but we can boost up.
LS 2.2L: Our complete turbosystem for Chevy's outstanding new Cobalt will be available soon. As seen in the JIN Cobalt on the Tuner Transformation TV show, this system continues our strong history of development for the legendary Ecotec engine. Projected power output is in the 230 HP range for the intercooled Stage II system. The same system with engine internal and fuel upgrades will be capable of supporting up to 500 HP! (use photos of JIN and our Cobalts)
#91
#93
Get low
i agree, the splitter on the front and the paint scheme is quite rediculous, but i wouldn't mind taking some few select parts from that motor.
#94
I am really looking forward to the garrett turbo, i think the gt85 disco potato is a better turbo for the cobalts. It kicks in at a much lower RPM and has a wide power band. The garrett kit should produce 200-230 hp they say and it will come with every thing you need including a pigyback ecu harness.
#96
yeah im gonna wait on my turbo till probally next spring by then a couple kit will be out and i wont have to take a loan out to afford it also give me time to prep a little with stronger internals
