Head Gasket
Head Gasket
Is this just a replacement gasket or can i use this for my turbo
http://www.crateenginedepot.com/stor...P2474C200.aspx
Thanks guys
Thanks guys
if your using arp head studs buy just a replacement, if you need the bolts anyway (cannot reuse stockers) then buy that kit, itll give you everythign you need at a good price.
you will also need cam sprocket bolts and a crank pulley bolt...all are tq to yeild and will need to be replaced once the head is replaced....
every done the timing or pulled a cyl head on one of these?
so another question is the lsj supercharger intake manifold work for our 2.2 i have a free one and was wondering if i can use it, i heard there is an adapter plate i can use
Yes, it will work for the 2.2L. You will need a different intake manifold gasket, but I don't think it will work for you. If you are already turbo'ed you probably have a custom fabricated intake mani. If not that is probably the best solution or you will need to buy a block off plate for the lsj intake mani to let you run a turbo application.
well its already order as far as parts for the engine i have pistons rods springs retainers head studs head gasket rod bearings and such. I got this intake mani for free so i figured i could make it work. I can order the adapter plate for the tb. I just want to know what else i need
09-28-2015 12:51 PM
