head gasket change
head gasket change
ok with the turbo build do i have to change the head gasket with only pushing 250 or can i leave the stock one on with out blowing up the motor. and im changing the fuel injectors so do i have to change anything else with this build
Not really, just stay a little under and you'll be fine. I'm going to try and keep my tune a little conservative, around maybe 230-240 until I get a little more built. This is, after all, my daily driver. Might want to upgrade to a 2.4 manifold, that's about it.
yea im upgrading the manifold to the one thay have at vulcan turbo since that one is way more better than the plastic one but your right since im doing a little bit of shopping for the internals but yea thanks for the advice
They're definitely nice, but if you're not going to push 15+ psi then you'd be better off with a 2.4 manifold.
hey the the manifolds we got are pure sex if your a show kinda person, its the way to go :p even if your on a stock engine, but all in all it depends on what your goals and how you want it to look, if you wanna look like the rest go for the 2.4manifoldf, if you wanna look unique and like u mean bsiness go with the vulcan aluminum right
importkiller
09-30-2015 07:18 PM
09-28-2015 12:51 PM
