Header WOES! HELPS!!!
okay guys so i get like 8 out of 10 bolts on my stock 2.2 header and then notice i do not have an o2 sensor on the header.....so i galnce at the SS header i have a poop it has an o2 sensor...now i remeber reading that i can plug the hole for the o2 sensor on the SS header right?? so i put all the damn bolts back on and am going to run to the hardware store...and ideas!?
It should be easy to find an exhaust bung kit at any auto parts store...
If you have a ride to an AutoZone, Advanced, etc...try those.
Pretty sure the plug needs to be 18mm x 1.5
I thought all the Eco's have two O2 sensors, though? Might wanna check to make sure...
mmm mine doesent have it on the header.....? is this normal i mean i really looked pretty good it would be in the same spot as the other header right???
07 and up 2.2 w/o SAI (AIR) exhaust manifolds do not have O2 sensors -- it is in the DP. Second O2 sensor is still after the cat.
05-06 2.2 w/o SAI has O2 sensor in the exhaust manifold.
Aftermarket header may or may not have the O2 sensor in it...did the manufacturer install instructions say anything?
05-07 2.0/2.4 SS and 08 2.4 Sport manifold has the O2 sensor in it.
hahah brillinat minds think alike i just finished fileing some of it out! im do a bit more...none of the stores here have the bolt or plug i need!!! can i order on on ebay!?
mmm i had an idea.....could i just buy an o2 sensor for the hole screw that bitch in and cut the cord off?? and if this will work would a 2.2 sensor fit into the spot on the SS header?!!
guys bumpsssss plzzz!!!!
BUMPPPPPPP anyone!?
BUMPPPPPPP anyone!?
Yea, a 2.2 O2 sensor will fit the SS manifold O2 hole...I put a GMPP extrude-honed mani (same as SS mani) on my 06 LS and just used the original O2 sensor in it.
Did you check any local hardware stores...one that specializes in bolts?
ss/sc's have one on the header one on the dp we have two on the dp stock
if you are swapping both head and dp then no problem just plug them back in if not then you will have to plug a hole
so to make sure i got this right we just need to take one of the O2's from the DP and put it on the header in that hole? and that won't cause any problems?
sorry to thread jack but does anyone here know if the header to block gasket differs from the SAI equipped 2.2's to the 2.0 gasket?
like shapewise. cause i'm going from a 2.2 header with SAI to a LSJ header and none of the chevy dealers around me stock the 2.0 gasket so i want to make sure there aren't any funky cut outs or anything in my stock gasket. cause i want to see if i can reuse it. otherwise i have to wait til tuesday.
heeeeeeeeeelp
see my other thread so we don't clog up this good mans thread. thankssz!
heeeeeeeeeelp
I told you the measurements on the plug you will need...
http://www.google.com/products?hl=en...num=1&ct=title
EDIT: Here you go, try a find something like this at the local hardware store.
http://www.verociousmotorsports.com/...ous%2Bproducts
Also, try calling any of the local dealerships and asking the service departments if any tech's may have a damaged O2 sensor laying around that they haven't thrown out yet...
parts stores are no longer allowed to sell plugs for the o2 sensors....even though the had them only dealerships can buy them ....some EPA BULL **** and yea i found a bolt that is like the one you posted!! thanks much guys! for future refernce the bolt people need to 18 mm with a 1.5 pitch!!!! good luck all
Great to hear you got it worked out. Stupid about the EPA **** since people buy parts for race builds from auto stores. There are so many off-road parts sold at those stores, they'd go out of business if the EPA banned them all. Just stupid...
I went back and bold the bolt pattern in my post from yesterday, you should bold it in yours too.
