headers
#51
alright so thats everything i need to run sportlines under fe5 suspension.
i went under the sticky and i found thie
FE5 part numbers
Struts: 15247245/15247246(L/R)
Shocks: 22728821
and than this
LNF/FE5 Part numbers
Struts: 19181044/19181043(L/R)
Shocks: 25793745
only one that matches yours is the 2nd shocks one
im guessing those numbers are from the 08 model?
also the shocks from gmpd comes with both right. it only says quantity one. i just wanna make sure it comes with both.
FE5 part numbers
Shocks: 22728821
and than this
Shocks: 25793745
#52
they are on fronts and backs. when i worked in a shop i always seen them on fronts and backs, unless some one turned rotors or drums before is the only time i havent seen them on both axles. when i turned my rotors and drums they were on mine. but i also have 17s and it used to shake. but after that it dont do it any more.
#54
FE5 part numbers
Shocks: 22728821
and than this
Shocks: 25793745
FE5 part numbers
Shocks: 22728821
and than this
Shocks: 25793745
I don't totally understand what your question is...the first set (FE5) is from the 05-07 SS/SC...the second set (LNF/FE5) is from the SS/TC (08-09). The LNF FE5 are the way to go...they were tuned for Nurburgring as far as I know. I just know they're better than the FE5 (SS/SC) struts/shocks.
Also, 1 shock is 1 shock...you have to select quantity of 2 for shocks and 1 each (left and right) struts...4 items total.
#55
So what is the difference between these part numbers.
Shocks: 25793745
$70.53 + $154.84 + $45.07 + $45.07=$315.51 + shipping.
Description says performance supension.
19181251 driver's side front suspension strut
19181631 passenger's side front suspension strut
25793745 rear shock absorber
09 TC
Mine are otw!
EDIT: About 305ish shipped. (Mr.NOObLaR)
Not sure those are the right ones.
Description says soft supension.
Shocks: 25793745
09 TC
Mine are otw!
#56
They are the exact same parts...the part numbers were updated to the ones you listed 2nd...the top set is the old part numbers.
They are EXACTLY the same still.
#57
Shocks: 25793745
09 TC
Mine are otw!
Shocks: 25793745
09 TC
Mine are otw!
z28addiction
09-28-2015 12:03 AM
