Help
Help
I have an 06 lt, every now and then it won't start, when I turn the key all power to everything goes for a while and they key won't come out unless I hit the switch in that little hatch under the steering column, but then a little while later it will just magically start up, also I've had my purge valve or whatever go and it throws a code so my check engine light has been on, well now after finally my car starts the check engine light is off, why?? Is it my starter thats bad?
