Help build problem
Help build problem
Hi I order a zzp gurdled block and it came in I order the 2.2 and it has the mounts for a engin oil cooler did zzp send me the rong block I'm lost cuzz I'm shour the 2.2 don't have it help any one
Did you contact them? Or does it say on the receipt? Maybe they add it because its awesome. Otherwise, pretty sure the block is the same. If you went with 86mm bore, it might be an lsj shortblock
