High Flow Cat
High Flow Cat
Hey has anyone put on a highflow cat? I heard the stock cat is very restrictive, Also if you have upgraded did you get a Cel? I was thinking about this high flow performance cat, think its good?
http://www.sfxperformance.com/parts/PAC800026.htm
High flow cats are restrictive because it's a catalytic converter...that's its job but it's less restrictive than your stock one. I would only suggest getting one if you're upgrading the rest of your exhaust and keeping the diameter the same (example: 2 1/4" cat-back piping, so you would get a 2 1/4" diameter catalytic converter).
As far as CEL with the Cobalts, I don't know.
right i plan on upgrading my exhaust to a custom or corsa 2.5'' so i figured i would need a 2.5'' catlalytic converter. Anyone recommend a certain brand?
I really like my dynomax
http://www.a-1performance.com/super_...converters.htm
or
www.dynomax.com and then go to master catalogue
or
I just can't beleive the factory cat is so bad. You want to see awful catalytic converters? Look at car from the mid 70's. Now those were restrictive!
Originally Posted by NJHK
I'm assuming you want 2 1/2" for boost (looking at your other post), if you're not, than 2 1/2" is too big for an n/a setup.
Why would it be too big? i plan on upgrading to a 2.5 exhaust wouldnt i need to upgrade the cat as well? or would i not have enough back pressure? Im not saying the old cat is crappy or anything i heard it true airflow is around 2'' .
Check this Thread
This is the link to a thread that I posted about a direct bolt in replacement high flow cat from Random Technology. It's not yet avaible but is supposed to be in the works. The 2.2L has a much more restictive cat than the 2.0L. The 2.2L cat has an outlet that measures just under 2.0".
https://www.cobaltss.net/forums/general-cobalt-68/2-0-2-2-2-4-high-flow-catalytic-converter-16263/
