high flow cats
high flow cats
I've been looking at high flow cats, and I've noticed that there is two rather different types around. The first one appears to be just a cat and nothing else and the other is an entire manifold to catback assembly. After looking at the mounts for my cat i didn't see a way to install only a high flow cat without welding. The full assembly although 3 times the price look extremly easier to install, bolt off-bolt on. SO my question is how does one install the stand alone cat, and is the more expensive assembly worth the extra 200 bucks?
its either a weld in or replace the down pipe. id saty spend the extra cash to get it done right and replace everything. you get a warrenty and dont have to worry bout the weld going bad if you were to just weld one in... just my 2 cents.....
