highest safe rev limit.
what is the stock '07 rev limiter?
and what is the highest you can safely rev a 2.2 with the stock valvetrain/internals?
i had my car dyno'd and they stopped it at 6300rpm and the power is still climbing, thats why im wondering. from what i hear the stock limiter is 6800 rpm, but the tach lags so i dont know.
edit: i know the power will level out around the stock rev limiter, but i figure with a tune i might get a little more up top. it might be beneficial to bump the limiter a tad
with stock valve springs (this is the limiter) it is 7500rpm
anything above that you risk valve float with equals valve tap which equals no runny runny
mine is set to 7000 and no problems
