hit 8000rpm
hit 8000rpm
IM now tuned by tirfecta around 7300 on stock intern.
to get 8100rpm what do I have to upgrade.
springs retainers .......
http://www.youtube.com/watch?v=dWuRo...e=channel_page
I LOVE MY ECOTEC
thx guys
I LOVE MY ECOTEC
thx guys
harden gears aka oil pump ect. springs, valves, ballance shafts.. i believe theres more. but i dont see the point in going over 7500 when all the cams out there drop off up there.
definately NBS and valve spings...more supporting mods you have the better.
welllll....I have the neutral balance shafts, adjustable cam gears and Stage 2 (2.2l) cams FS if you're intrested
on a N/A car, your doing nothing but revving the **** out of your motor.
On a supercharged car, you will make power up to redline...within reason.
Whats the point of wanting to rev to 8.1k rpms? Just to say you can?
The LSJ makes no power above 6500 on the stock cams... on cams it doesn't make more power just holds it past 6500 with cams.
Look at the power graphs for the 2.2's in the HP thread. They all start loosing power about 5500ish
The TVS will keep going past 6.5k. I'd love to be able to tell you how far....but mine belw up before getting that high ;(
Even on the TVS the cams don't allow it to push the required air to continue to make power...
The TVS forces the air in... but the cams and valves only allow so much air to be crammed in!
c1 or c5 what difference between. there was 2 civic GSR one stock and one stg 2 cam
like someone already said, not true. I hit my max hp at 6850rpm and i have my rev limit set at 7000rpm. All i have is 2.8/60, CAI, Meth, H/E and 1 Step Colder plugs which r actualy gapped to big.
If I could find my dyno sheeet I'd show you that you'd continue to make power past 6.5k ...at least with the mods I had...(I think I hit my max at about 7K w/stock cams)
found it; yup...hit max HP at about 6.8k and stayed over 400 until about 7.3k. I guess maybe my mods could have made the difference specially the adjustable cam gears.
