Hp???
Hp???
How much hp and torque can a 2.2 withstand b 4 having to replace stuff?
And im looking to get around 400 hp so what all would i need to replace?
Evan
Evan
for 400 hp really all u would need to change would be the rods/pistons and maybe valve springs but if ur already tearing apart the engine u might as well do it all at once.
go here for a lil more insite:
http://www.hahnracecraft.com/auto/Ca.../HRCEcotec.htm
I'm old school
I can help you here. The info above is all pretty accurate. I have just finished doing the necessary upgrades to my car for a street legal 400 HP car. What is your goal with the car? Everyday driver or just track use, or something in between? Mine is an everyday driver.
I have just finished installed Eagle Rods, Wiseco reduced compression pistons, Bates engineering valve springs, and GM Performance adjustable cam gears. That should give me a block that can safely handle up to 600 HP.
Don't forget about your trans. Which one do you have? The manual will require a better clutch for that kind of power. The Automatic will require a bit more. I have the auto. It now has a limited slip differential, high stall torque converter, high output fluid pressure pump, and many improved internals such as clutch packs. My trans can now handle about 400 ft/lbs.
How are you going to make that power? Turbo or nitrous? That will play a role as well.
And don't forget about your half-shaft's/CV-joints ..... I'm sure the stock ones would snap pretty quick with 400+HP& torque.... Halfcent, ...Any idea how much the stock half-shafts can withstand btw.... just wondering...
I'm old school
Specific stats, no. I have heard from Hahn Racecraft that the stock half shafts on GM front wheel drive cars are about the strongest ones made by any manufacturer. There are still aftermarket ones out there. I haven't bothered to do those yet since it wasn't a really weak link in the chain. If they break, I'll replace them with upgraded ones without any problems. Until then, stock is good for me.
The only time I have heard of the shafts breaking is due to wheel hop. If you are gripping or slipping, you are ok. If you are bouncing, snap-a-rooney.
I have an auto, and i plan to put a stage 3 turbo in it, so basically i need to replace rods/pistons, valve springs, pressure pump
whats a torque converter,camgear,and clutch pack?
I'm old school
Originally Posted by wolfwood390
quick question, whats a "build book"
Anyway...
Valve springs, don't have too, but easy to do while you are in there, and the gains greatly justify the very small cost.
Pressure pump, uh, which one? The trans fluid pump I will assume. This would be done by a performance tranmission shop building you a custom trans. You can't really just replace the pump, its kindda part of a package.
Now your what is questions.
I love to help people with their builds, but I fear you might be a bit behind the curve here if you don't know what a couple of those things are. I would suggest learning a little about cars first before you proceed to tear into one. Especially a brand new one like a Cobalt. But anyways, here are BRIEF descriptions. Try out howstuffworks.com for really good tutorials on transmissions.
A torque converter is the automatic transmission equivilant to a manual trans clutch. It is a fluid turbine that allows the engine to turn (like when it is running at idle) while the wheels stay put (like when you are in gear with the car is sitting still holding the brake). It connects the engine to the transmission.
A cam gear is just a gear on the end of the cam shaft that allows the timing chain to turn the cam shaft. The other end of the chain is connected to the crankshaft.
A clutch pack is a large set of disks (like 10) that are all stacked on top of each other inside an automatic trans. There is a set for each gear. Again, this is a set of parts that a performance shop would install as part of a package deal.
Hope that gets you going in the right direction.
Halfcent, how much did the auto tranny upgrade run you? I just bought an 06' LT auto and I'm thinking either upgrading the stock one or getting the GM race tranny out of the Phase5 from GM Performance. whats a better deal?
Permafried-
I'm old school
Originally Posted by celicacobalt
half cent, what can i run on my 2.4 ss automatic as far as psi goes, i was thinking about 6 psi or possibly 7 psi before buliding tranny and internals?
I'm old school
Here's a link to the build book in pdf format from GM...
http://www.gm.com/company/gmtunersou...build_book.htm
I'm old school
Originally Posted by forcedgminduction
hey halfcent,
how are you planning on getting your power. are you using the hahns turbo kit or something else?
