I Need Advice on Removing A Engine
I need some advice on removing the engine, after unbolting all the obvious engine mounts and disconnecting the harnesses, what is the best route to do this, should I take the engine out from the top, or should I raise the car up around the engine and then slide the engine out?
Thanks.
Thanks.
I would support the subframe and then unbolt it and then raise the car up and pull it out if you have the ability to get the car up in the air high enough otherwise it's through the top FTW...
Thanks for all your replies, I have the space to pull the engine up but I think I will be taking the engine out from the bottom.
Thanks again.
Thanks again.
