I want 200WHP...NA
I want 200WHP...NA
To begin, do not turn this into a "not worth the money" or "L61 < LSJ" thread, or ill simply delete the thread.
I'd like to get my 05 2.2 up to 200WHP...while staying away from Nitrous, Blower, or Turbo.
Currently have:
Intake
Header/DP
GMPP Touring
Trifecta tune
Motor/tranny mounts
I've got Stage 1 comp cams on the way, and I'm planning to do the 2.4L manifold swap as well.
On top of all of that, what else would I need in order to reach 200?
I'm considering the new mrz underdrive pulley, or maybe just the lighter oem replacement...would this help at all?
What else? Any and all suggestions welcomed!
Currently have:
Intake
Header/DP
GMPP Touring
Trifecta tune
Motor/tranny mounts
honestly u could ummm.. sell it all and buy an ss...
but on a serious note.. ull have to build it more then likely.... or at least bump up the compression and run sum race gas...
take out your engine, replace with bigger engine.
heres what you would need to do IF you wanted to do this
INSANE compression sumting like 14:1 (jk)
cyro'd block
ported head
rods/pistons/headgasket/studs sleeves
stroker kit
ported intake manifold
race gas
entire valvetrain upgrade
injectors
custom tuning
oh
but you wont have any traction so
new tires
and new axles to handle the new tires
and then a new clutch
hmm... probably like 15,000 dollars
cyro'd block
ported head
stroker kit
race gas
injectors
custom tuning
oh
new tires
if you're going to stay NA ( or just add nitrous)
you can run 11.5:1 pistons some rods to take it .. cams ported head full bolt ons and a tune and you have a chance.. you're going to need run stg2 cams though stg 1's aren't going to be wild enough for you
^^^ basically what he said.. however you're not going to need a cryo'd block and the race gas part you probably wont be running all the time so i wouldn't factor that in...
a slight over bore would help too
axles wouldn't be necessary either.. full mounts and some good tires would be good
cyro'd block
ported head
stroker kit
race gas
injectors
custom tuning
oh
new tires
cyro'd block
ported head
stroker kit
race gas
injectors
custom tuning
oh
new tires
https://www.cobaltss.net/forums/show...ht=dyno+thread (my refrence)
thats ~45% more hp
i dont understand why op doesnt want to go to a power adder. If its because he thinks hes sacrificing drive ability/reliability. i think he needs a new N/a goal.
lol im cranky since its late, not much tolerance for people.
oh and 15k was me exaggerating. but i think its realistic that this will cost more than any turbo kit out there. at least ~5k
It's just something I'd like to do...some people want to use power adders, I'm interested in keeping it all motor. No particular logic behind it, I simply don't want to go the F/I route.
It will likely cost me slightly more then a turbo kit..but I wouldn't imagine anymore then 1-2K more.
N/A power comes from revs...first and foremost will be upgrading the engine / valvetrain to handle at least 8000 safely...maybe 9k tops. Cams to shift the powerband to the upper reaches of your rev range...supporting mods to hold it all together...ported head, anything remove the airflow restrictions.
Honda S2K engine should make a good blueprint. Research what's on those. Or what people sink into built H22 engines. Then find the American version.
Edit: Or make one of these. I'm pretty sure it makes over 200whp n/a
https://www.cobaltss.net/forums/drag-racing-52/ok-i-guess-now-ss-116534/
cyro'd block
ported head
stroker kit
race gas
injectors
custom tuning
oh
new tires
cyro'd block
ported head
stroker kit
race gas
injectors
custom tuning
oh
new tires
Definately rods
Definately a ported head
Bigger injectors for sure
Better intake manifold for sure
New tires will also be a given... unless you just like to sit and spin
Tune
If you do all the work yourself you are probably looking at $5500 +/- $1000. And these are just the bare minimum things and even then you would be pushing it to get to 200whp. In all reality you would also need to upgrade the suspension to keep it safe at higher speeds as well. To run enough timing to actually hit 200whp you will probably need to use 100+ octane gas as well.
So pretty much I agree with greased. If you want it to be really reliable you will need pretty much everything on his list. I think his figure maybe a little high, but you are probably still looking at almost $10K if you want the car to be reliable at 200whp.
Bolt Ons:
Intake...$200
Exhaust...$450
Header/DP...$500
2.4 Intake Manifold...$250
Underdrive/lightweight crank pulley...$200
Total: $1,600
Engine Work:
STG II cams...$400
Fully built head (port, 1mm over size valves, valve springs/retainers, etc.)...$2500
11.0:1 pistons in a .040" overbore...$400
new rods for these pistons...$400
Neutral Balance Shafts...$400
New headgasket and head studs...$250
Motor/Tranny Mounts...$300
Custom Tune...$300
Total: $5,100
Overall Total: $6,700
Those are your necessities...
Then you can go into parts that arent necessary but will help at a track
STGII Axles...$??
Drag Radials...$??
Clutch...$??
Mind you, these totals are not including labor, so you better do your own work. However, in your defense, this will probably end up being more of a 250hp car
Intake...$200
Exhaust...$450
Header/DP...$500
Total: $1,600
Engine Work:
STG II cams...$400
Custom Tune...$300
Total: $5,100
STGII Axles...$??
Drag Radials...$??
Clutch...$??
For a large engine, you can work at increasing the HP by increasing the torque produced. You can do this because most large engines are not very efficent per ci at producing torque. Smaller engines on the other hand produce a whole lot of torque per ci so you have to look at some other way.
If you want to ignore FI and Juice, your only option is revs. Lots and lots and lots of revs.
Bolt Ons:
Intake...$200
Exhaust...$450
Header/DP...$500
Total: $1,600
Engine Work:
STG II cams...$400
Custom Tune...$300
Total: $5,100
STGII Axles...$??
Drag Radials...$??
Clutch...$??
Intake...$200
Exhaust...$450
Header/DP...$500
Total: $1,600
Engine Work:
STG II cams...$400
Custom Tune...$300
Total: $5,100
STGII Axles...$??
Drag Radials...$??
Clutch...$??
this seems like your most logical options. your biggest gains will come from the pistons and the head but you need to really do your research. IMO all motor cars are twice as technical to build than FI.
I think it would be pretty sweet to see some carbs on a custom intake myself. just remember anything is possible with enough time....and money
Bolt Ons:
Intake...$200
Exhaust...$450
Header/DP...$500
Total: $1,600
Engine Work:
STG II cams...$400
Custom Tune...$300
Total: $5,100
STGII Axles...$??
Drag Radials...$??
Clutch...$??
Intake...$200
Exhaust...$450
Header/DP...$500
Total: $1,600
Engine Work:
STG II cams...$400
Custom Tune...$300
Total: $5,100
STGII Axles...$??
Drag Radials...$??
Clutch...$??
