I want 200WHP...NA
#51
the only thing that may hurt your streetability thats been mentioned so far is your cam choice, depending on how aggressive the cam is (you have stage 1's, which will definitely limit your ability to get to 200whp) and high comp pistons. Depending on the compression ratio, you may need to run race gas to prevent any knock.
I'd give you 160?whp with bolt ons, tune and stage 1 cams...don't know for sure though as I don't know anyone that has dyno'd with your setup.
#53
You don't think too hard, that's for sure.
I believe because when you put in better cams, the vibrating would be very annoying or something. I hear if you have an manual tranny and put in new cams, that you'll will have a hard time not stalling the car because of the crazy idle.
#54
not talking about block str. anymore. he needs to bore it out if he wants to get anywhere. no replacement for displacement... cept forced induction and apparently its overdone
#55
200hp is nothing these days, It will cost you like 5k in parts and advil to build a 2.2 to 200 and then you have a unstable engine that has so many things that could go wrong, that youll get halfway down the track and something will explode.
If you get a 2.4, you could do some of that stuff and get away with like 230 all motor.
#56
BUY A 2.4 CRATE ENGINE, AND BUILD THAT. It will be cheaper, and more reliable. Do some bolt ons
triflow cams ported head and full bolt ons obviously a tune lol
#57
I applaud the OP for even having the ***** to post this question on such a biased site. Of course the guys and gals of Cobalt SS are gonna tell you to go blown, its how their cars come, and its the cheap and quick way to power. A dialed in NA engine takes more finesse, take more work, takes (maybe) a little more money, and doesnt yeild the same results.....but if thats what youre into GO FOR IT!!!!!
First of all I think 200whp is a perfectly reasonable goal. That right around 225hp at the crank, which on a 2.2 isnt rocket science, nor will it totally degrade drivability or durability(that one is just silly, this is coming from guys puting superchargers and turbos on stock engines, but anyway...) And yes its only about 225hp crank, I have yet to see any proof that the F23 causes anymore than approx an 11% power consumption(feel free to prove me wrong)
So what do you NEED:
Free flowing air intake: got it.
2.4 manifold: $240
Header/DP: got it( a different header size/brand/design may help depending on what you have now)
free flowing exhaust: got it(upgrading to 2.5" would be a good idea.
Balance shaft delete or neutral shafts: free-$450
Stage II or similar cams: $400-800
Valvesprings:$350-700
Ported head:$1000(possibly upgrade to LSJ head=$500)
11:1 pistons: $550-675
Head gasket/bolts(studs) $235
Tuning:$free-550 (Trifecta update cost?? other source??)
So thats from $ 2975-$5150(plus labor if you cant do work yourself)
You dont need a block, sleeves, stroker kit, you dont need cryo treatment, you dont need valves, you dont need rods, you wont need race gas, your car will be daily drivable(probably about a 1100-1200rpm idle) you dont need a clutch, flywheel, etc....etc...etc...
Hunterkiller was pretty much spot on, and as he pointed outif you go towards the $5000 end of this youre pretty likely to get closer to 215whp with a spot on tune and proper cam choice/installation(this is starting to approach the limit on 91/93 octane imo)
The only major item I would add as a solid maybe to the list that hasnt been mentioned is an upgraded ignition system, more specifically a box with timing curve control.
2.4 manifold: $240
#58
2.4 manifold: $240
Hunterkiller was pretty much spot on, and as he pointed outif you go towards the $5000 end of this youre pretty likely to get closer to 225whp with a spot on tune and proper cam choice/installation
2.4 manifold: $240
the only way i see this ever hitting 200 whp is 8000 rpm limiter and ungodly low torque. congratulations on turning your cobalt into a honda
#60
yeah, ok, really? cuz im pretty sure a s/c doesnt affect driveability at all if tuned properly. However, cams will ALWAYS reduce driveability. unless you do a VVT mod and good ******* luck w/ that.
I didnt mean for you to think that i was saying forced induction causes drivability issues, I made my comment after the word "durability" and that is the trait I was referring to being potentially reduced by forced induction.
7000-8000rpm is absolutely where this combo is gonna make power, and there is no reason to believe that for some reason the torque is just gonna go away because we increase hp and the rev limit. It surely wont have 250+lbs torque like a mean blown engine will but there is no reason to believe we'd be sacrificing torque, Id be willing to wager that this combo would make torque equal to a lightly modded LE5.
And the Honda comment...... "some people you just cant reach"
No, they dont. the lifters dont even touch the cam in an ECO. However if the followers have significant or uneven wear they will need to be replaced, but this is not a requirement for the given power level, its just engine building basics.
#61
basically your creating the ultimate roll car...
oh and some hondas are aweome (the ones that are turbo'd like 25 psi crazy ****) but id honestly rather have more low end torque... its just way more fun to drive
#63
2.4 manifold: $240
2.4 manifold: $240
As it stands now, I'll be intalling my stage 1 cams until I decide how far to go into building the motor. Would you recommend replacing anything like valvesprings or retainers when these are installed? 74000KM on the motor...
#65
Stage1's dont require any valvetrain upgrades, with the proper tools replacing the cams is about a 1.5-2hour job(actual time, not what youll pay) for someone with experience doing it. To replace the springs/retainers/keepers your looking at about another 1.5-2.0 hours actual time with the proper on car service tools. Without these tools it will take significantly longer and may actually require head removal. If you plan on stage 2's later, or you plan on road racing and you can swing the money for springs and trust someone to do the job the right/quick way, or you can do it yourself, then I'd say go for it so you have the headroom/piece of mind. But there is NO NEED to do them now. Most stage 1 type cams peak in the 6500-6800rpm area , and the stock valvetrain will survive that so long as you arent bouncing off a 7000rpm redline all the ttime.
#66
If I were to go ahead and upgrade the valvetrain at the same time, are there any particular parts/brand you would recommend?
Also, to anyone who may know....at what level of mods would larger fuel injectors be needed/beneficial? I know that up until a certain point, the duty cycle on the stockers isnt near being maxed out, but when should it be considered?
Would full bolt ons and cams be enough to warrant upgrading them to say stock ss/sc injectors? Or is it strictly only needed if I were to go with a big power adder..?
#67
Again, thanks for the info.
Injectors will most likely be fine even with the cams, but yes, a fully modded NA 2.2 is probably near the point to where you would switch to SC 32#'s
Theres no reason to remove the head to replace cams. Or springs for that matter.
#70
Keep in mind also that LSJ injectors power the supercharger as well. 200 whp in an LSJ requires 15-20% more fuel than 200whp n/a, based on the loss from the s/c.
#71
mhmm truth. your BFC is around .5 ish and the LSJ is around .6-.7 (someone correct me if i am way off but its just an approximation)
#74
#75
It's just something I'd like to do...some people want to use power adders, I'm interested in keeping it all motor. No particular logic behind it, I simply don't want to go the F/I route.
It will likely cost me slightly more then a turbo kit..but I wouldn't imagine anymore then 1-2K more.
i plan on ripping my car apart once the loans paid off..i want to convert mine to rwd with a v8.
