iat
160????!!! if not mistaken as the other guy said thats extremely high unless you re talking about coolant temp my iat is 1-2 degrees warmer than the temp outside but i have a cai
IAT= Intake Air Temperature. Normally, not an issue for 2.2's. It's a big problem with us s/c'd guys tho. If ur IAT's are that high, ur in big trouble. If your coolant is that warm, no big considering you should have a 180* thermostat
no its my iat i got a k&n sri and i have an interceptor gauge, and i was just sitting there in traffic and i scrolled through and seen it but once i take off it goes back down but still it was high while being still. my coolant was around 198
Even 140 is a bit on the high side for us. IAT2's shouldn't really ever go over 120, 110 is about as high as you wanna see them go
why do you guys insist on answering questions if you dont have a clue. AIT in traffic dont matter, what is the difference between ait1 and ait2 at WOT thats when it matters , of course your damn iat is gonna rise if your not moving.
dude....198? that's way high too. you need to get urself a 160* thermostat to keep those temps down. What kind of traffic are you sitting in?
once again , you cant give a number for ait2 and say its not suppose to go above that number unless its stupid high like when your pump is dead etc. You have to tell the difference between the outside temp which is ait and iat2 which is the intake temp then we would be able to tell you if its too high or not.
i understand that but the temp over where he is are not that high thats why i said 160 is too high
plus its only a 2.2 or 2.4 so i dont think it should get that high when outside temps are no more than 80
NJHK
08-08-2008 01:50 AM
