iat reads -40f. Need Advice
my lt/sc can't get tuned correctly until this is fixed. There is no shorts to ground anywhere and it is wired up correctly. i checked it 10 times. I just put in a new 2.5 map sensor because we thought that was the problem. still no dice. I am unsure of what to do next. Any advice on further troubleshooting and/or your own experiences with this issue will be greatly appreciated.
If I can't fix this, it may be the end of having a supercharger on my car so I could really use some guidance.
yeah it does come from the maf. Pretty sure there are no shorts or opens but I am going to re-do all the wiring just to make sure. I'm familiar with the probable causes but wanted to see if anyone had additional input, since it may be something a bit more complicated to fix.
Are you watching with the HPT scanner I assume? If there's an open circuit relating to the MAF, you can just unplug it and see if there is any change on the scanner. If the temperature reading still reads -40, then there is an open circuit. I don't remember for sure if the temperature reads the maximum value or the minimum when there's an open, but it should be easy enough to figure out. I do know the MAF frequency will read the maximum value with an open circuit.
