ignitions?
Originally Posted by SHR3D3R
im saying the motor, not the electronics
that ecu is not setup to read boost, and the fmu is probably a rising-rate unit, which isn't going to do all that great either if at all considering you're already at 60psi static at the rail. I hope you're not planning on stock injectors either.
good thing i got my boots on cause the **** is getting deep in here, dude if you think it is gonna work then put it on the car take some pictures and prove us all wrong but until then i am now gonna raise the bs flag sky high,
#38
Hey, let's keep this about the turbo and not bash the j-bodies RedBaseBalt! I know of quite a few out there that can hand you your ass...
As far as the kit goes, shouldn't be that big of a deal to run over to the shop and snap a few pics Shred-meister. If you're not full of it, then show them up. If not...just sad
#39
I'm old school
This thread is nothing but trouble. I'm tempted to close it. Instead, I will attempt to offer some clarity and see if I can straighten a few things out.
I have said it before, I will say it again. There is NO turbo kit for L61 equipped Cobalts. Read this. Then, read it again.
The pictures above are a combination of file photos from Hahns mock-up back when they first started turbo charging Ecotecs and a Dyno of the JIN car. They used an FMU and larger injectors for that setup. It is old news.
Maximum Boost is a joke. You will be disappointed.
Yes, the Cavalier and the Cobalt use the same basic L61 engine. But they are mounted in a completely different engine bay using completely plumbing. None of the Cavalier charge tubing will fit. It also has a completely different throttle system.
#40
yeah that was the 2.2 prototype i think i remeber some one saying they got the kit working but the stock ecu really doesnt agree with it there was still to many problems to release to the public
satisfied
10-19-2015 12:35 AM
