i'm at a loss...what is this?
the end plate on that thing hanging off the block. the silly little man at the dsm tuner shop called it a cam sensor. which is funny cause it ain't and it's pissing me off cause i want to fix it but i have no idea what exactly it is i'm fixing.
and yeah the leak is orginating from this component.
If its on the drivers side on a 2.2 I think it has something to do with oil going to the power steering. Had the same thing on mine. It was kinda expensive too for some reason, just short of 500 to fix.
it doesn't feel like a big deal not losing enough oil to flip about and my 06 doesn't have a cam sensor i got it back in september of 05.
that area is the front side of the block on the drivers side where the power steering unit is on the average gm with our setup.
Not 100% sure on the inner workings of the system, but electric power steering. Does this even use oil?
just brake clean it off and call it a day. From the terrible picture, id say its the cam rear seal cover, it it right below the oil fill cap?? Should be 2 bolts and the cover comes off, the new seal looks like a rubber band.
every modern car has a cam sensor.
Any chance of a better pic, so we can get an idea where on the engine this "thing" is located?
You can just remove the 2 bolts on the cover, remove it, clean it up, put in a new seal reinstall and your good to go. 30 minute job if your REALLY slow, lol...
thank you and that area is right above the oil filter housing. sorry about the lame pic but i figured even anyone knew what they were looking at they'd more then likely know what's up. if you look in the lower left of the pic you see the 2.4 intake mani, fuel inj and the rail. not hard to figure out were it's at.
yo faulk i'm gonna get right on that. you know the part # on the seal? anyone.
Mine did that, had it in three time under warrenty to fix it. The last time they sealed it with some **** that never seemed to dry, dosen't leak tho so **** it.
