Injectors
Also I would recommend some split-spray injectors like
https://secure.fuelinjectorconnectio...lve-heads.html
These our made for dual valve intakes like ours. More spray on the back of the valves and less on the walls of the intake ports.
I'm glad I asked this question now. So ev6 with no adapter ev1 with adapter and splitsprayed are ideal. I have never seen anything about splitsprayed injectors on the forums before. Do you run those one personally?
Yeah I don't know why more ecotec people don't use split spray as they are designed for two valve setups. You'll get better atomization during idle conditions and less wall washing. I am pretty sure our stock injectors are split spray.
However, I did run conical spray pattern injectors before and they worked just fine.
Doomstar
03-26-2016 03:47 PM
