injen short ram VS. cold air
ok every 2.2L out there running the injen let me know what you have had better luck with,running the short ram or the cold air. I have tried both and cant really tell what i like the best. I did notice the short ram has a quicker throttle responce and my exhaust is alot louder with it.......and the cold air i didnt really notice anything...the only thing i did notice is the intake has been on the car for 12k miles and i took it of to clean it today and it was clean as hell......so give your feedback lets see what everybody out there thinks
Bro honestly the responses you get here will be 50/50.
Technicaly speaking you should go with a cold air intake.
Very simple : More cool air = More power. Not more hot air.
The throttle response doesn't matter once that warm air gets to the motor.
It's all about cooling the air. Hence intercoolers for turbos and sc's
Originally Posted by YoAdrian
I wonder how much "cooler" the air really is by having an additional foot or so of piping. The air near the asphalt is pretty warm also. Just a thought.
It's not about having an extra foot of pipe it's about the location in wich the air comes from and it's temperature.
Air coming from the engine bay is very hot.
Air coming from the wheel well is a lot cooler.
Are you telling me that the air inside your wheel well is the same temp as the engine bay? No.
Asphalt has nothing to do with a CAI.
I don't care what anyone says.
Colder Air = More Power!
WHAT?
I realize this. However, how much cooler is the air near hot asphalt than the air a foot above it. I am just trying to figure out how much cooler it would be.
What does asphalt have to do with a CAI?
The cone of the CAI is surrounded by your wheel well cover.
It isn't even exposed to asphalt in any way shape or form. It's covered.
So asphalt heat doesn't touch the cone wich is where the air begins to enter the intake.
However if you have a short ram engines heat does surround the cone and that's not good.
Is it not closer to the asphalt than the short ram?
I'm done going back and forth on this subject.
I know CAI's produce more power and that's it. I have seen it on dynos.
Good luck with your purchase primetime.
Calm down there buddy.
I am pretty sure that the cone would still be close enough to the asphalt to be subjected to it's high temperature. I am not trying to start **** man.
I just know what i'm talking about in this case. That's all.
To each their own right. Later bro.
like i said its been on the car for 12k miles already so im not purchasing one, i already have it.... the injen cai can go both way short ram or cai.......and i have seen a car go both ways on a dyno and the short ram produced 1-2hp more then the cold air and the way my car is set up the short ram is getting the same air as the cold air....i just took the car down the street and i not only heard but also felt the difference between the two.....so while the cold air looks better i think im gonna stick with the short ram for a while....what i was looking for was feedback from other people who might have tried both set ups on the same car to see what their results were, match up feedback to see what they thaught not what somebody read in a magazine....thats all i was tryin to do didnt want a war to break out
two words heat soak cai is the way to go your gonna get the same hp either way but witht the cai you get the power at the top of the power band and short ram will give the power closer to the bottom of the powerband but with the sri heat soak is always a problem
I use CIA all year round except for in the winter. I will convert the injen to SRI when winter comes around just cuz it snows alot here in michigan and dont want to get it full of snow and salt and everything else they use on the roads in the winter.
I have an injen and have it set up as a CAI. I'm not gonna get into CAI vs. SRI......pointless! I agree, when winter comes, I'd rather be sucking in the "warmer air" to keep my engine warm vs. sucking in cold (very cold at time, MN).
I've had it installed as CAI sine the day I put it in. It's louder than stock, and I can notice a slight boost in performance. SRI I can't help!
If it means anything from my experence with both setups....i noticed a lot of head soak with the short ram set up...i liked the way the cia sounded and the way it made the throttle feel
I have the injen CAI and all I know is after a hot day of driving around the air inlet tube with the cold air section on is really cold compared to the short ram which you can barely touch.
i have mine set up as short ram, and i havent tried it as cold air yet, but the other day after driving for a while in 100 degree weather i couldnt even touch the tubing it was so hot so i will be switching to cold air soon
