Installed Stage 2 Comp Cams Yesterday
#101
LOL.Well since this turns the tables and i have Stage 1 and matt has Stage 2 i think that this would be fun and find who makes more power and where!!
Im really excited
Im really excited
#105
I would pop in the stage 3's but my main concern is if I did go supercharger down the road,would I be wasting money if they won't properly work well with each other,or hold of completely until I get the supercharger and get the cams.That would be a hard decision to make honestly.
#107
I wouldn't mind the spray but people said by the time you keep on refilling it you could of bought a supercharger or turbo.I think its a preference though on what people want with their cars
#108
the blower is going to require a different setup in valve timing which is why the blower cams have different lift durations. the NA cams require a certain amount of scavenging to fill the cylinder and cool it at the same time. the overlap in the cam profiles used on NA cams isn't neccesary for a system that forces the air in. you can use the stage 3 cams but you will need the cam gears to adjust the valves overlap timing.
edit: that's why i'm running two bottles, yeah baby.
#109
well I am going to build up the motor either way,I rather play it safe then sorry with a turbo or a supercharger.Just wasn't 100% sure if the stage 3 ones would work well with the supercharger.
#110
"Dear heavenly spirit, thank you for providing us with direct port nitrous injection, four core intercoolers, ball bearing turbos, and titanium valve springs, Amen" LOL
#114
#115
I wasn't 100% sure which cams to use exactly,but spankey's monkey said I can use the adjustable timing gear with the stage 3,but if the blower cams will work fine with the supercharger then I don't mind running the blower cams then.
#120
::Looks at Forks laying on ground::
::Picks up one::
::Sticks into socket::
::Picks up other fork::
#121
the cams with the 113200 part number are stage 1, 113300 part number are stage 2, 113400 are stage 3 (N/A builds these are most common for) 113150 part number are turbo grind and 113250 part number are a blower grind... the boost cams are not considered stage 1 or 2 or anything, just turbo n blower. the other part numbers have stage 1-3. so therefor spanky is right, you have stage 1 cams!
i do but i guess not many others do man... unleash on the kids b
#123
yea, i learned the hard way about two years ago with installing those stage 1 cams copson20 just put on. i was 180 out on intake and bent valves snapped a lifer . thats why i now have full valvetrain and stage 2 113300 part number is what i have now
#125
i have no idea. thats just what the mechanic said at the dealer. i mean everything was in right and turned fine by hand. when i went to start it just cranked n cranked and then backfire and high pitch ping noise. then pulled cover off to see all the rockers laying next to head studs and a snapped lifter
and that got me pissed so i pulled the head and just got all new **** and built the valvetrain n forged pistons/rods all at once.
