installed TTR solid mount :)
did some mods last night after unistalling interviewatruins blower set up...
BEFORE:
AFTER:
need to work on centering the cover correctly, was dark so i guess i didnt align it right, also going to paint match the cover to the blower and valve cover, and doing the little line things in silver to match the coil pack
BEFORE:
AFTER:
hmm it depends if i get the tc i want with the gauge that has a/f boost and all that built into that little display screen. if thats the case, i'm asuming you want it back? what about the aem as well? lol.
if so, you have dibs
Also interested in how it feels...I thought I read somewhere that once it's been on for a while, it doesn't vibrate as much...but how much does it really cause for vibration?
I have a all solid ttr mounts. When I adds this moun I felt a small increase in vibs, but only between 1000-1300rpm...after that it felt normal. And normal to me is not normal for those with stock mounts. I've already gotten acustomed to solid mounts. So to me the car feels like an other
Give it a 1000 miles or better, and make sure you have tranny bushings (poly) as having a solid mount on one side and soft stock on the other side seems to lead to more vibrations... Just a thought.
Last edited by TurboTechRacing; 10-01-2009 at 05:58 PM. Reason: Automerged Doublepost
It works wonders on the ss/sc.. You do feel more vibs at lower rpms.. It also changes the way your motor sounds on the inside when the windows are up.. Strange, but true. Works fantastic though, and I have had mine for about 2-3k miles now, and the vibs aren't as bad as they were when i first got it.. Amazing product IMO
I've got a full set of poly mounts from you guys, best mods ever, put down 220wtrq@2k on the dyno :p glad to know i get to lay it all down on the pavement when i go the track...now if only i could get this fueling issue resolved...fuel pump may be going out
