jdbaugh1 official "build" thread
#451
Actually took of work a little early yesterday so I can get this thing wrapped up. I need to at least get the thing moving under it's own power so I can move on to more important projects that I should be working on right now instead. It's a busy time of year but after 6+ months it is time to have this thing running again.
All wires terminated at Mil connector. The black thing right under Opt. B tank is a shrink tube that will go on the back side of the connector which they refer to as "back-shell". I will wait to apply heat gun until I verify the wiring is right.
Luckily the valve cover is threaded which I installed a bolt to zip-tie the harness to keep it away from the belt. Engine mount still isn't installed because I'll need it out of the way to sync the timing.
Car has 14 lbs of dust from sitting so long
This is now the main pump as it has much better flow rates for a given resistance/pressure than the stock pump. Davies Craig DC-9040. It has a brushless motor. The hoses pretty much hold the light pump in place so the zip-ties should be more than sufficient to keep it from swinging around. Did not want to drill or tap the subframe.
Still utilizing the stock pump. Both pumps push into each heat exchanger
Water to air intercooler configuration
#453
jdbaugh1 (06-19-2019)
#459
Had high hopes of starting the engine, for the first time, after converting to AEM Infinity 508 ECS but of course ran into an issue. When I went to calibrate the throttle body and the computer tried to move the blade around nothing happened, it just error out. So first thing I assume is wiring issue so I remove connector at TB and AEM and use my multi-meter to check continuity and everything checks out. So I assumed maybe I had the wrong pinout diagram so Trevor sent me what he had or found. The diagram he sent did not match the diagram I had because it had the +5V references flipped with the 0-5V ground references as well as the open/close circuit for the blade so I'm excited because that is an easy issue to correct. So I flip all these wires around and it still does the same thing. I was messing with it again this morning before work and discovered I had installed the terminal block below 180 degrees off were it should have been so the Fan 1 relay, I repurposed to be the EFI Main relay, was not sending power. So I flipped the block and everything seems to be working now. Trevor has been helping me using Team Viewer in setting up the initial calibration by modifying the setup he has for Chris's car. After I sync the crank timing with the AEM we should be trying to fire this thing up tonight.
Terminal block that was rotated 180 degrees off
In order to use a timing light I borrowed I hacked off the rubber boot on an old lead so I could stick it in the coil and have it make contact.
#468
Hell I don't know why they would care. Their supplier is the one who eats the cost so the actual store shouldn't even be out anything unless their supplier starts rejecting them. I sheared an axle clean off that I got from Carquest and I know the guys there and they know my car and they warrantied it.
#473
I have a video of the actual first time I started up which I'm thinking about posting up because it might give y'all a laugh. I have the passenger side motor mount removed because I'm having to us a timing light to sync the AEM timing with the mag trigger wheel. So I have the engine supported on a jack stand from underneath and I had the engine up just a bit to high and with my phenolic spacer combined with my 1/2 spacer for water/methanol injection the supercharger pulley is normally about 1/4" from the front top brace in the engine bay. Well the pulley/belt were contacting the cross brace which sheared an outer rib off my belt and made quiet a ruckus. Scared the **** out of me.
#474
Rigged up a piece of stainless wire to make it easier to use a timing light to sync the engine with the AEM. The numbers on the ATI are freaking tiny and this process was a PITA.
Finished Mil spec connector
Obligatory engine bay picture
I felt bad cutting into these floor mats but turned out alright I think.
And now for the good ****. Just starting to get the tune dialed in on power. Still just running a bit rich.
BTW, if anyone savvy has any ideas about what could be causing the noise for my IAT sensor your opinions are welcome.
jdbaugh1 (06-23-2019)
