jdbaugh1 official "build" thread
Old 09-10-2019, 02:38 PM
  #501
exninja's Avatar
interviewer: "what was your senior project"
me: "we built a regenerative-braking bicycle"
interviewer "oh"
Old 09-11-2019, 07:04 AM
  #502
royce777's Avatar
Originally Posted by jdbaugh1
I would do it in a heartbeat now. But at the time I was more concerned about having spare time to party.
this is so me lol
my undergrad I was zero involvement. I mean I still made good grades, graduation with a 3.8 and now my graduate program I am super interested in learning as much as possible and making good grades again.
Guess it all comes with age
Old 10-21-2019, 09:04 AM
  #503
jdbaugh1's Avatar
Went to my local SCCA groups "Octoberfast" even where they setup the course for speed. Hit 85mph on some runs. Not much technical but was still a ton of fun.
Old 01-07-2020, 03:25 PM
  #504
jdbaugh1's Avatar
Haven't done much in a while but recently switched over to control my methanol injection PWM signal with the AEM Infinity. This involves using a "lowside switch" output from the AEM which triggers a Hella solid state relay to handle the electrical load of the water/methanol pump.
The water/methanol pump is now grounded and receives positive on/off pulses from the solid state relay which has to be supplied power from another relay that only gives it power when the key is on. If I don't do this my AEM and the relay decide to turn the injection pump full on when I turn the key off. I've also installed a flyback diode which other water/methanol injection controllers include integrated based on what little I could find online.
I currently have the AEM set up generate a 250hz PWM signal and basically have the duty cycle for injection start at 25%. The pump doesn't like lower "voltages" than that. The injection duty cycle is driven from a combination of throttle position and boost pressure. This way if I hammer on it I can have the injection start before boost pressure is even generated.
Old 11-28-2021, 10:17 PM
  #505
IonNinja's Avatar
Any idea what size the barb fitting is in that MAP sensor hole?
Old 11-30-2021, 09:58 AM
  #506
Rattlesnake Race Shop
USMCFieldMP's Avatar
Whoa, sneak attack from an old member! Unfortunately, I feel like I haven't seen JD post in like 6 months or more.
I put a barb in the MAP sensor hole of my LK9 manifold... I can check and/or try to remember what size mine was. I want to say I needed to thread it with 1/4" NPT... and that the barb was 3/8". But I can double check on that.
Old 12-08-2021, 07:20 PM
  #507
IonNinja's Avatar
yeah back from the dead. Thanks for the info, bought a couple on my own to try and it is indeed 1/4" npt to 3/8" barb
2.2balt
06-25-2014 02:05 PM
elite_Cyborg
10-08-2010 02:21 AM
cruisn
06-23-2009 12:23 AM
cruisn
Canadian Mid West
02-13-2009 09:10 PM
red2006SS
09-16-2008 10:24 PM
Quick Reply: jdbaugh1 official "build" thread
