Just another 2.2L going turbo thread!!!!!
Well i wasn't keeping it secret, i was just in fear of my build being jinxed for posting before i'm done, but i waited until things were really happening before i made this thread. Now i don't think much will stop me, i have ran into several snags along the way, including one today with my oil return, but i don't care, i just wanted to share and discuss and i'm so damn close,lol.... POST UP THE MINUTE YOU GET DONE, LOL!!!
Not a Sebring
Adding some go to all that show finally Brian? :P
I'm stoked to see how it goes man. You truely will the trifecta Cobalt (street, go and show) after the turbo build is complete
i should be ok now
So make a thread, i wanna see!
Quick update....All charge piping and bov install complete, minus one stupid coupler, i ordered 2 and the company shipped out one, dumbasses. Magnaflow Cat on the way, thanks to TTR... Hopefully after this weekend everything but the exhaust and the tune will be done!!! IF i get time to work on it,lol....
#36
5 spd, my clutch probaly wont last a week, lol... Planning on a spec stg2+ ,shortly after i get it out of my garage and can take it to work to put one in, will be easier on the lift.
I'd like to dyno, i just want to get it running and keep it together for a while,lol...
I don't know what spring i want to run in my wastegate, i have a 6lb spring and a 9lb spring for my tial 38mm, i'd like to run the 9 but i think that may be pushing it on the stock motor. Normally you tend to run alittle higher do to backpressure and stuff, so im nervous,lol... They make a spring in between those 2 but its another $30.00. How do you think 9lb would do with this turbo on the stock internals? BOOOMMM!!! lol....
Thanks!
Thanks!
#38
Boost contollers work great if you get a good one, but i'm not going to chance it on a stock motor!!!! I think i'm gonna start with the 6lb spring and see how close i am to maxing the maf and injectors, then go up from there, i will run whatever i can get away with as long as i have safe afr and knock#'s. This car will not get beat on alot. To much invested in it to go out and beat the **** out of it!!!!
#39
#40
Ok just thought i would bump this up. This thing is a down pipe, a tune and a prayer away from running, hopefully sometime in the next week or so. Added a few pics...
#43
Thanks guys, i should have the downpipe fabbed up and welded this week, waiting on my flex coupler, but once i drop it off at the welding shop, it will be up to them for how long it takes...
#45
2.5" SS, i would have ran 3" but the turn off the turbo was too tight and i have dual magnaflow 2.5 mufflers that i really like so i figured a mandrell bent 2.5 wn't be to bad. I am half tempted to leave the cat out of it,lol.... I just don't want it extremely loud.
#47
I think you will be fine. the turbo muffles the sound a good amount.
#48
#50
Very nice!
i wonder with the placement of the turbo, will there be any oil build up in that line... everyone knows a turbo hates oil pressure! you could start it up and with in minutes blow every seal in the turbo.
but i see you have it set up to rung the charge pipe under the car not to shabby, i was told i should, but i dunno i love the look of it up and over the motor, PLUS i work in construction and didnt wanna risk ******* my charge pipe up like my floor is lol
good job on the build so far, i just turned my boost up to 11PSI, but i gotta turn it down again, im running 12.5 on my A/F
