Just another 2.2L going turbo thread!!!!!
Old 04-08-2009, 11:03 AM
  #51
Sentry's Avatar
Originally Posted by pykie
Very nice!
i wonder with the placement of the turbo, will there be any oil build up in that line... everyone knows a turbo hates oil pressure! you could start it up and with in minutes blow every seal in the turbo.
but i see you have it set up to rung the charge pipe under the car not to shabby, i was told i should, but i dunno i love the look of it up and over the motor, PLUS i work in construction and didnt wanna risk ******* my charge pipe up like my floor is lol
good job on the build so far, i just turned my boost up to 11PSI, but i gotta turn it down again, im running 12.5 on my A/F
Yep, that drain line looks great actually, shouldn't have any issues.
Is that 5/8"?
Old 04-08-2009, 12:05 PM
  #52
b_faulk75's Avatar
Well ,my biggest concern is the drain for the turbo, i won't know until i start it if oil is backing up into it. I spent alot of time thinking about that after Sentry had issues. But i really don't have alot of choices due to how low the turbo is. The drain line is only -8 an, I thought it was -10 when i ordered it from vulcan but that is all he sells. Originally this turbo had the same size drain on it, so i don't think that will be an issue. It has a restrictor in the feed side so the oil pressure should be very low, so hopefully no issues. Thanks for looking guys, i will update as i go. Shouldn't be to long though.
Old 04-08-2009, 04:18 PM
  #53
Sentry's Avatar
Yep, I thought mine was good, but it was way too small. I have a feeling I've got insane oil psi going to the turbo. I replaced my lines with 5/8" and yesterday I cranked it with no smoke at all. Before, it was burning the oil up in the turbo because it was backed up.
Got a couple of leaks still, but hopefully I'm about done. Good luck with yours.
By the way, did you use RTV on your oil flanges? What kind of sealant is that?
Old 04-08-2009, 06:10 PM
  #54
b_faulk75's Avatar
Using GM pipe sealant, good for oil or coolant, i also used some gm gasket sealer on the inside of the pan fitting just to be sure. What size was the line you used before? I was kinda aggrevated when i realized i only had -8 line, but i didn't pay attention when i ordered, so my fault i guess. BUT i do have a restrictor in my turbo so that should help, and with such a short path to get to the pan i don't think i will have a problem...
Got my injector harness today, gm harness from an 04 cavi, works perfectly. Gm stg 2 injectors, have to put them in yet, hope i don't have the fit issues like you did,lol.... Mine's an 05 and we have a different fuel rail, so it should work out also...
Old 10-24-2010, 11:58 PM
  #55
b_faulk75's Avatar
I just saw the turbo thread link pop up and saw my original post, i thought i had updated the thread, just wanted to say it's been completed and running strong on 10lbs of boost for quite some time, no issues to speak of...
Old 10-25-2010, 12:09 AM
  #56
Spanky's Monkey's Avatar
good to see everythings golden
Old 10-25-2010, 03:17 AM
  #57
elecblue06's Avatar
awesome you ever get vidz of one of the sickest 2.2s on the site lol
or any more pics of it?
Old 10-30-2010, 04:22 AM
  #58
08ShowbaltLS's Avatar
for real, can we get pics and vids?
Old 10-30-2010, 02:28 PM
  #59
b_faulk75's Avatar
There are a bunch of pics floating around somewhere, no videos, but a few members from the site have rode in the car and can vouch for it running good...
Full turbo back 3" Exhaust, Yes it's crush bent, but it flow fine for what i'm doing...
Old 10-30-2010, 02:56 PM
  #60
elecblue06's Avatar
what size piping is your intake? and do you have any trouble with it rubbing on anything?
Old 10-30-2010, 03:40 PM
  #61
b_faulk75's Avatar
I think it's 2.5, it doesn't rub at all, i had to play around with the piping to get it just right but it's been great...
Old 10-30-2010, 04:32 PM
  #62
elecblue06's Avatar
alright good to know
Old 10-31-2010, 10:19 PM
  #63
wow clean build! any track times?
Supercharged06SS
12-11-2022 04:47 PM
06MetallicBalt
08-17-2021 03:40 PM
ThoR294
10-04-2015 08:44 PM
maliki778
10-01-2015 07:39 PM
09-26-2015 06:44 PM
Quick Reply: Just another 2.2L going turbo thread!!!!!
