Just came in the mail...
Old 02-14-2009, 06:00 PM
  #101
HunterKiller89's Avatar
Originally Posted by Area47
torque convertors eat power
auto trans kills it even worse.
...im a little confused here. wouldnt the auto trans only make it worse BECAUSE of the torque converter? This being why DSG trannies are so awesome...its still clutchless, but has no power loss from a TQ cnverter.
You make it sound like two separate things.
Mind you, the tranny will definitely slow him down due to lacking a 5th gear, so the 3 forward gears are all taller than in an F23, but that shouldnt show on a dyno..only on track times.
Originally Posted by Sentry
Yeah, I loaded mine yesterday. You gotta be really careful when you do any kind of computer reflash. If you accidentally turn off the ignition, or if the battery goes out, you can totally screw your ecm. You will have to tow it to a dealership because it will not start, and they will void the warranty if they can see you messed with it. Then you have to pay a lot and your warranty will be toast.
Just something to think about, lol. I don't mean to worry anyone, just don't be careless.
just FYI, this isnt true. It was back in the day (and i mean as recent as late 90' and early 2000's), but GM fixed this issue. Mine restarded during a reflash...the tuner froze . I freaked out, called vince, asked if i needed a new PCM, and he said relax, just restart everyhhing, and explained.
I guess the ECMs these days have like..2 "slots" for tunes. The factory tune is in slot 1, and slot 2 is unused. When you (or GM) uploads a new tune, it loads to slot 2. Once the tune is fully uploaded, it takes the spot of slot one, and becomes the default tune, and slot 2 is erased.
It doesnt work exactly like i said, but thats the easiest way i could explain it.
Old 02-14-2009, 06:03 PM
  #102
NWAE Cobalt's Avatar
Originally Posted by DebadgedBALT77
depending what you want for the cams, id be interested. possibly downpipe combo.
nonono...down...i r has dibs on mp cobalts cams, intake mani and tb
  #103
DebadgedBALT77's Avatar
you have any vids/pics of your car hunter?
Old 02-14-2009, 06:13 PM
  #104
Rent me! per hour
Area47's Avatar
um. they are two separate things that work together to transfer power.
the internals of a TC draw power to turn through the fluid then to lock it after a certain rpm is reached. then the clutches in the transmission slip and lock on the shaft. driving the pump, clutches, blah blah blah take more power to turn than a manual. hence why auto cars dyno lower than manuals.
people give me **** for my dyno numbers, and yet this is the exact same dyno i use.
Old 02-14-2009, 06:26 PM
  #105
MP Cobalt's Avatar
I'd be keeping the downpipe maybe to put on the new car. It would bolt right up.
Old 02-14-2009, 06:27 PM
  #106
damnnnn. oh well. i was hoping noone claimed the cams, but it looks like someone did. gheyy
Old 02-14-2009, 06:29 PM
  #107
i know how a TQ converter works, and how it drains power...but on a 4t45e arent all the clutch packs engaged electronically via solenoids, so there wouldnt be pumping losses? I thought all additional drivetrain losses on an automatic versus a manual were caused by the torque converter, since there isnt really a solid connection between the input shaft and the output shaft of the converter (assuming the converter is unlocked). So a auto with a locked T/C would see the same power as a manual...
Im not arguing, but this is how i understood autos for the last 3 years...so finding out they are different than i knew kinda throws me off
and no, i dont have any track times or dyno numbers. Maybe in the spring, but until then, all i have to go off of is my interceptor's bhp estimate
Old 02-14-2009, 06:31 PM
  #108
MP Cobalt's Avatar
yeah I'm sorry man. I might keep them or i still might sell them
Old 02-14-2009, 07:17 PM
  #109
Rent me! per hour
Area47's Avatar
a manual car will always put down more power. thats a given. we know this obviously.
you get the general idea of it. hence his lower than normal numbers
Old 02-14-2009, 07:24 PM
  #110
I fully understand, even though you werent talking to me.
Old 02-14-2009, 08:05 PM
  #111
ok..so...is what i said correct then? lol.. i kinda wanna know for my own sake, but yes, i understand that autos wont put down as much power
100% METH
02-16-2012 02:48 PM
SuperChargedMA
02-01-2011 12:36 AM
badbaltguy
01-06-2010 09:30 AM
Mr McCabe
07-13-2009 12:46 PM
Quick Reply: Just came in the mail...
