Just installed a drop in K&N filter
Old 02-19-2006, 08:43 AM
Steeltown Pursuit's Avatar
Hi all,
I've read about modding the stock 2.2 intake and removing all of the stuff under the airbox but since it's been so cold lately, I just installed the drop in k&n filter and took the car out for a spin.
I must say, with just the drop in alone, there is a noticeable difference. I know the car feels more responsive and definitely revs up a bit faster (I have an auto trans)
I've noticed that with just the drop in filter, it's definitely louder as well. I would imagine it would be even louder if I removed all of the stock baffles under the airbox but so far, it's a great little mod that takes little effort! I would recommend those of you with an auto tranny to go ahead and get the drop in filter. just for the responsiveness alone I think it's a worth while mod to do.
I'm almost content at just leaving it how it is now (without removing the baffles) but may attempt removing the restrictions when it gets a little warmer out.
just thought I would share
Old 02-19-2006, 11:39 AM
mkulrey13's Avatar
I was also thinking about the drop in, dont have the $$ for a CAI, well see.
Old 02-19-2006, 12:34 PM
Roadrunner's Avatar
i am up on par with you, i also installed a tb spacer with the new filter.
i def noticed the gain after i installed the intake filter alone.
Old 02-19-2006, 03:44 PM
HackAbuse's Avatar
I just did the airbox mod last night, and i ordered a K&N filter on the internet last night.
Damn is that thing louder after that airbox mod
Old 02-19-2006, 04:03 PM
Roadrunner's Avatar
what is this airbox mod that you did?
Old 02-19-2006, 06:19 PM
HackAbuse's Avatar
You disconnect the air intake after the flter box, which removes about 7-12" of useless plastc tubing from the air intake
Old 02-21-2006, 06:10 AM
how much louder is it with the airbox mod? is there really a major increase in power when you remove the airbox?
i leased my car so I'm trying not to do too many things to it, but if it's worth it... i'm up to removing all the extra tubing...
what do you guys think.. is it worth doing? (the airbox mod)
Old 02-21-2006, 06:49 AM
Malaclypse's Avatar
Tonight I removed the resonator/duct assembly from the front fender. The intake tract is so loud you can feel the vibrations in the car. Time to turn up the radio.
As for the derrier dyno? 2nd gear feels alot better (That's likely an illusion)... but that's about it. Personaly, I wouldn't bother until you have exhaust work done. After that, the biggest restriction to the motor breathing is the throttle body.
So, in order this is what I'd do:
2.5" cat-back Exhaust
Injen or comparable CAI.
UD Crank pulley
Header, 2.5" DP + high-flow cat
Larger throttle body if possible.
My idea is that once you're able to afford and install all the above mods, a larger (useful) throttlebody assembly will be on the market. Or you could just bypass that entirely and go after the GM Performance Parts custom intake manifold ready for an LS1 TB.
Old 02-21-2006, 07:28 AM
blkcobalt's Avatar
You guys aren't getting the CEL? I know that seems to be a problem with the 2.0 SC's.
Old 02-21-2006, 11:50 AM
$$ WILL $$'s Avatar
i was thinking about getting the k&n myself. but i would never pull **** off my car . u dont need to be heard to be seen in this car.
Old 02-21-2006, 12:26 PM
boston69's Avatar
K&N installed
I just installed my K&N CAI last Tuesday and have yet to get a CEL. I have a 2.0 and I didn't remove the negative battery terminal as instructed. I am not that mechanically inclined and it took me about 2 hours and that was because I took my time. I was PO that I cracked the plastic fender wall while trying to get it back around the brake. It sounds pretty cool when you start to hear the supercharger at higher RPMs. I have also noticed a so soslight increase in power. It was worth the time and money IMO. I've put over a 100 miles on it so far with no CEL and, knock on wood, hope I don't get one. Good luck to anyone else that decides to go for a K&N CAI.
Old 02-21-2006, 04:38 PM
IonNinja's Avatar
you guys are exaggerating on the intake resonator removal...there is not even a huge difference in noise.
My exhaust sounded slightly louder but nothing extra from under the hood...and no power increase. I'd only recommend it if you're bored because the difference before and after is minimal.
Old 02-21-2006, 10:15 PM
T Dawg's Avatar
The bast part is the baffle removal is free, and it is louder. I didn't tell my wife that I did it, but she asked what I did to get it louder, it's not much, but everyone notices. As for performance, a little response, but not much power increase
Old 02-22-2006, 01:51 AM
hectanooga's Avatar
Ditto.
Old 02-22-2006, 01:56 AM
Malaclypse's Avatar
Originally Posted by hectanooga
Ditto.
You two have got to be either deaf or kidding. You're letting the intake tract of the motor resonate WITHIN the entire fender. It makes a big difference in noise... but not in performance.
Old 02-22-2006, 02:11 AM
hectanooga's Avatar
My bad, I thought I edited the part of his post that I was quoting. I was ditto'ing what he said about power increase. Out of all the cars I have done box mods to, I never notice power increases.
Old 02-22-2006, 03:51 PM
hackeragent061's Avatar
does the k&n filter help any
Old 02-22-2006, 04:17 PM
RedBaseBolt's Avatar
K&N adds about 2-3 hp with resonator delete mod of course. Also makes the car a HELL of a lot louder than stock
Old 02-22-2006, 05:04 PM
IonNinja's Avatar
It does not make a big difference...installing an intake makes a big difference in noise...removing the resonator gives just a hint more sound. Nothing to write home about...definitely not shaking anything in my car.
As I said, my exhaust note was a tad louder but as far as engine noise, and that reving sound you get with an intake for instance, not there...
Old 02-22-2006, 05:11 PM
^^ it is with my car. It's nice and loud.
Old 02-22-2006, 06:28 PM
niknyce's Avatar
It makes a big difference... my friend did it to his 4 door, its wayyyy louder then mine without the intake mod
Old 02-22-2006, 06:46 PM
importkiller's Avatar
dude, you may not notice as big of a difference in the saturn cause they use alot more sound deadening material in the ion that the cobalts have, if you guys want i will put up a sound file for you to prove how much better it sounds
Old 02-22-2006, 06:49 PM
sshaner's Avatar
yes please put up a link for the sound diff.......
Old 02-23-2006, 10:53 AM
how do u do a resonator delete
Old 02-23-2006, 11:27 AM
Jack the car up and take off the front right wheel, remove the wheel well far enough that u can reach into the opening with a wrench and arm , unbolt the resonator and pull out wheel well. Instant Intake sound after doing it too.
This combined with a K&N filter is good for around 2-3 hp.
Quick Reply: Just installed a drop in K&N filter
