L61 Turbo/Super (forced induction) Information Thread
Old 09-11-2014 | 10:22 AM
  #351
Kiddj246's Avatar
Will this turbo manifold work on my 08 2.2l
ZZPerformance - Ecotec Stainless Turbo Manifold #ZZ-ESSTMAN
Old 09-11-2014 | 10:58 PM
  #352
andrewcarr1993's Avatar
Yes any manifold works on any of our Ecotec engines.
Old 09-11-2014 | 11:34 PM
  #353
Kiddj246's Avatar
Cool thanks I have the flange adapter and a holset turbo to slap on when I get back it being a 08 2.2 coupe that's the LSJ correct and Andrew it says your from Clarence I'm from buffalo how's your cobalt handle in the winter I'm moving back to buffalo next year this time
Old 09-11-2014 | 11:54 PM
  #354
Well last year I was on brand new all seasons and we had a ton of snow, they were 225/45/17 and I'm selling those and getting actual snow tires, thinking 205/50/17 this time. It was great on 195/65/15's that were also brand new but that wasn't lowered, so it really depends on tires, and I really should take off the swaybar since it's down so low. On the plus side since my charge pipes are under the engine they'll stay colder.
Ask about any turbo info, I'm a 2.2 turbo but my 09 is a LAP, stupid SAI is causing an exhaust leak since they integrated it into the head after 08 so you're good there. So rather than spend any money on this engine I'm getting a LE5, hopefully as soon as next week then I'll be heading to PRS to swap it out on a weekend.
Yours a F23 car? If your asking if your engine is the LSJ, no it's a L61.
Biggest thing with that turbo is how it'll mount, also is the exhaust v band or some weird bolt pattern, you'll probably have to make a custom DP. Hopefully yours will be easier than mine. Very old picture but all I could find.
Old 09-12-2014 | 05:04 AM
  #355
Kiddj246's Avatar
Il take a couple of pics of it when I get off work amd il post them
Old 09-12-2014 | 10:18 AM
  #356
Kiddj246's Avatar
Here's one pic I have a couple more excuse the mess getting ready to end deployment
Old 09-12-2014 | 10:28 AM
  #357
Kiddj246's Avatar
Here another pic
Old 09-12-2014 | 04:41 PM
  #358
Did you say you have something for the exhaust side to connect it like normal?
Old 09-12-2014 | 05:24 PM
  #359
Kiddj246's Avatar
No I said I bought the adaptor for it to connect to that turbo manifold from zzp
Old 09-13-2014 | 01:01 AM
  #360
But after the manifold you have that weird thing to the DP, have an adapter for that too?
Old 09-13-2014 | 04:38 AM
  #361
Kiddj246's Avatar
No I was gonna take it to a exhaust shop and have them make me one idk what that paters is even called to buy one
Old 09-14-2014 | 01:05 AM
  #362
Kiddj246's Avatar
Would I have to change anything on the intake side like the manifold or throttle body?
Old 09-14-2014 | 01:21 AM
  #363
Both are up to you they both can hold up and the TB really won't be a restriction as it can be NA.
Old 09-14-2014 | 11:12 PM
  #364
06_ion2's Avatar
Originally Posted by Kiddj246
Trying to piece a kit together for my 2.2 I have a holset turbo he221 will that do me any good It was given to me and it's brand new still in the box I researched it and it's a diesel turbo idk if that matters will it be ok on my cobalt?
No buy a diesel truck instead. Will be much better to mod.
Old 09-15-2014 | 08:11 AM
  #365
Kiddj246's Avatar
Not really into the whole truck thing.
Old 10-01-2014 | 12:40 AM
  #366
Spanky's Monkey's Avatar
If you can find the setup, the 2.4TB and 2.4IM are **** on boost.
Old 12-30-2014 | 03:24 PM
  #367
silverado82481's Avatar
who has sucessfully supercharged a stock 2.206 ls cobalt ??? I see tones of information here and there but i want to know have you done it what did you use and how has the car ran snice.. I see people on here arguing all day that turbos are better then superchargers and vice versa. All i want is to get to the 250 ish HP range cause i dont want to rip the stock motor apart Im in Maryland and when you call the guys around here they say jsut buy a faster car. thats not the point...... i have this 06 cobalt that i dont have any payments on its a stick so the girl has no intention of driving it i wanna puut some pep in her step.
so im leaning more twords super charging but when i looked up some kits there was not ahole lot of imformation or mabey there was and im just too new to understand any of it
so have you done it did you get to 250 HP and is the car still running good
thanks
Dana
Old 12-30-2014 | 04:11 PM
  #368
06 cobalt is a bust unless you tune through Trifecta and they have had a bad record of shipping out late tunes. You can boost the 06 but I can tell you from personal experience the Trifecta Tuning solution leaves much to be desired.
Old 01-11-2015 | 05:21 PM
  #369
TFD's Avatar
TFD
Oil and water feed for turbo
Hi people,
going to turbocharge my 2.2 with a Garrett T25G turbo. Got a few "check" questions:
Oil feed: Feed from one of the three oil plugs below the exhaust port. M12x1.75 thread.
Oil return with the drilled hole to the oilpan.
Water feed: A) From the drain bolt from the waterpump. What thread size is this?? Anyone? Don't want to tab a new thread if not needed.
B) Put a T into the 3/4 coolantline.
Water return: T into the reservoir returnline or drill/tap a return into the thermostat housing.
Can you guys confirm or correct my findings please.
Thanx,
Daniel
Old 01-11-2015 | 06:49 PM
  #370
I would also like to know the thread for water pump drain
Old 01-12-2015 | 05:46 PM
  #371
TFD's Avatar
TFD
Got this from the Z22SE forum:
Hi Daniel,
The coolant drain bolt (part no. 90537623) is M12 x 1.5 x 12
Hope that helps.
Old 01-14-2015 | 01:23 PM
  #372
thanks
Old 01-23-2015 | 04:34 AM
  #373
TFD's Avatar
TFD
Got myself a flange today... but...
Looks like my EGR is open. Is this bad (think so) or should I/need I block the hole (gonna disable my EGR anyway).
Thanx
EDIT: Answered my own question. This is the EGR hole/inlet. When removing the EGR this hole can be left open. Or get a SAAB 9-3 gasket and close it.
Old 02-20-2015 | 10:49 AM
  #374
TFD's Avatar
TFD
No one with water return pics or something?
Old 02-20-2015 | 01:26 PM
  #375
I use the lnf thermostat housing, it has a banjo for water return
