longer rods = higher rev?
Old 05-10-2008, 05:27 PM
Witt's Avatar
Originally Posted by bridfi
right, im not talking about chaning the distance.
i want to rev high. im asking whats easier on the engine, so i can rev higher. im not talking about changing the rod length to change the piston's traveling distance. but i would think that the taller rods would increase C/R slightly?
To rev higher generally you would want to destroke it as it reduces piston speed.
hatrickstu's Avatar
No... you will be decreasing COMPRESSION. With the shorter rod... the piston will still move the same distance (hence, the same amount of STROKE)... but it just won't be doing it in the same spot.
If you want Higher Revs though... you don't Stroke... you DESTROKE. And you could do that by installing the LSJ Crank & Rods... but then you need a new Flywheel, etc... it gets complicated.
gotcha, thanks man
Rattlesnake Race Shop
USMCFieldMP's Avatar
is the LSJ's setup better for F/I?
i would think so, thats why they changed it. so i can increase my gains with an N/A build by taking the L61's setup a step further, by shortening the rods and increasing the stroke?
Just sell it and buy a used 2.4L...
Or sell it and buy my car ($16.5k)...
Old 05-10-2008, 05:28 PM
bridfi's Avatar
or custom crank.. which is already making my wallet hurt..
Old 05-10-2008, 05:30 PM
88958620 Ecotec Billet Crankshaft
MSRP: $4,948.57 Your Price: $3,679.90
This full race billet 4130 steel crankshaft comes internally balanced and uses a 1.888 inch rod bearing and a stock main bearing size. The stroke is reduced to 3.505 inches for high RPM use. This will result in approximately 2.0 liters of displacement when used with a 3.400 inch bore.
Hurting on the Wallet for sure...
bridfi's Avatar
let me just ask this, because this is getting confusing.
can i rev to 8000 with my factory crank/rod dimensions (aftermarket rods of course)?
so i can just get taller pistons to achieve my C/R desired?
RooTBeeR's Avatar
yeah, and that kid will too lol
Old 05-10-2008, 05:31 PM
bridfi's Avatar
jesus. thats like my entire budget.
lol im still researching. gotta plan first.
Old 05-10-2008, 05:32 PM
Probably... when you start revving really high... you have to look at other things too... like:
What RPM will your Valve Springs start floating? For an LSJ, it 7200rpm. Any higher and your car will go BOOM.
RooTBeeR's Avatar
just get higher compression ratio pistons if you don't want to spend a whole lot...still cant quite rev that high though.
Old 05-10-2008, 05:34 PM
  #36
bridfi's Avatar
well i would build the top end, with dual springs per valve...
hmm.. think i can get to 250 hp at the flywheel with that setup revving at 6500?
  #37
Just buy a NOS kit and put in some forged Pistons & Rods...
You'll be able to spray the hell out of it and make more power than a Stroker/High CR will give you. A lot more than 250hp as well...
Old 05-10-2008, 05:36 PM
  #38
bridfi's Avatar
im really trying to stay away from nitrous.... just dont like the idea.
i want to have that kind of power all day, not only when i hit a button.
Old 05-10-2008, 05:37 PM
  #39
I didn't use to either. But its power... good power.
Old 05-10-2008, 05:39 PM
  #40
blissmaster13's Avatar
My head hurts....I guess that's what I get for trying to keep up with experienced guys.
Old 05-10-2008, 05:43 PM
  #41
bridfi's Avatar
its very interesting..
http://auto.howstuffworks.com/engine1.htm
watch the video, and keep this in mind:
from P to O is stroke.
from O to M is rod length.
M, being the piston, if taller, will compress the gas/air mixture more, compared to a shorter piston.
Old 05-10-2008, 05:53 PM
  #42
RooTBeeR's Avatar
...I dunno, 100 hp with just high compression pistons doesn't seem feasable. you could get closer to that with head work though, you could do cams, porting, valves and springs maybe...I also am no expert, i just have some mechanical knowledge(as for these particular computerized enginges though I don't know much)
  #43
Just buy my car... change the Valve Springs and rev it to 8000+
Old 05-10-2008, 05:54 PM
  #44
I don't think it is possible to make 100hp with High Comp Pistons while still using 93 oct.
NAWZ or F/I is your answer.
Old 05-10-2008, 05:56 PM
  #45
InfinityzeN's Avatar
You can get longer rods without changing the crank and it will allow you to rev to a higher rpm. However, you will need to get the rods custom made and then have the pistons custom made to match.
For example, if you wanted rods that were 5mm longer, you would have to get custom made pistons with a pin hight that was 5mm lower. And since your getting custom made pistons, you can get them in almost any CR you wanted.
To clear something up here, if you want higher revs, it is: Shorter Stroke, Longer Rods
I would suggest a full valve train replacement, head work, neutral balance shafts, and cam as well. You have to make sure your engine can breath well enough to go to the higher rpms and that you have enough cam to make power there.
Old 05-10-2008, 05:57 PM
  #46
bridfi's Avatar
alright. thanks.
  #47
RooTBeeR's Avatar
we don't even have 93 out here in cali, only 91 is the highest pump gas
  #48
bridfi's Avatar
yeah it sucks.
what do you think i can run the C/R at with 91 octane? 12:1?
Old 05-10-2008, 05:58 PM
  #49
Witt's Avatar
Heres one of those ricer calculators to figure out static compression ratio horsepower increases. No idea how accurate it is which is why I call it ricer.
http://www.wallaceracing.com/hp-cr-chg.php
Old 05-10-2008, 06:03 PM
  #50
bridfi's Avatar
thank you. most straightforward post yet.
cool, ill check it out. thanks
Quick Reply: longer rods = higher rev?
