longer rods = higher rev?
Old 05-10-2008, 06:04 PM
  #51
Rattlesnake Race Shop
USMCFieldMP's Avatar
Originally Posted by Witt
Heres one of those ricer calculators to figure out static compression ratio horsepower increases. No idea how accurate it is which is why I call it ricer.
http://www.wallaceracing.com/hp-cr-chg.php
LOL...
Your old Compression Ratio of 9.5 and HP of 270 is now calculated
as a Compression Ratio of 10 and 273.75 Horsepower.
as a Compression Ratio of 12.0 and 286.49 Horsepower.
  #52
RooTBeeR's Avatar
Just a higher c/r will give you 5hp tops acording to that calc^^^
Old 05-10-2008, 06:06 PM
  #53
InfinityzeN's Avatar
I think it is pretty close actually. Seems if I went from stock to 12:1 (and I could keep my car from blowing up... HEH!), I would go from about 251whp to 266whp. Normally the calculations are 2.5~3% for every 1 CR of change. The higher you go, the closer to 2.5 you get. Only time you'll see 3%+ is when your working with very low compression ratios, such as found in old cars. You ever see what happens when an old flathead is bumped to 9.8:1 CR? Beautiful. Averaged ~4.5% per CR.
Old 05-10-2008, 06:08 PM
  #54
bridfi's Avatar
whoever made that up is a retard. i tried 155 at 10:1 and then at 12:1 it said ill have 165.
yeah f***in right.
i sure hope not. spending the $500 on taller pistons is going to get me 10 hp?
id rather stick with full bolt ons
  #55
Witt's Avatar
I changed my static ratio in my LSJ only because the new cams brought effective compression down a bit so I wanted to make up for it. Thats the only time I ever increased static on any car.
Old 05-10-2008, 06:14 PM
  #56
Sorry bro, but it's the truth. Should have researched it. You would have seen that a 0.5 CR increase will only net you about a 1% power increase.
However, you might as well get the higher CR if you are getting custom made rods and pistons to allow you to hit higher rpms. The higher rpms will net you more power with the breathing work and cams.
And since you would need custom pistons to go with the longer rods, anything you would gain from the higher CR would basically be free power, since you needed to buy the custom pistons anyway.
Old 05-10-2008, 06:16 PM
  #57
bridfi's Avatar
well at least i found out before i bought the parts.
i thought an increase in cr would make that hp jump. guess not.
true... so basically all the power ill be getting from the build is from the built top end, not the higher CR.
****, might as well go with a small turbo build....
Old 05-10-2008, 06:21 PM
  #58
Hahn RaceCraft's Avatar
I'll add a few cents:
Shorter stroke engines are favored for high-RPM durability due to the reduced strain on rotating and reciprocating assemblies (cranks, rods, pistons). Yes, they produce less torque than their longer-stroke brethren, but the additional power cycles created by the higher RPM capability more than make up for it.
All else being equal, a given engine that has its stroke reduced will then receive longer connecting rods. Increase the stroke, and the rods get shorter, but something else also happens that increases stress...
When we increase stroke and use a shorter rod, the mean rod angle is increased. This is not a good thing, for this significantly increases wrist pin and piston skirt loading, and it magnifies strain on the rods themselves too. As such, rod angles are a big factor when designing an engine combination.
With any of these aspects, there are practical and physical limitations as well, so far as wrist pin diameter, piston ring packaging, internal engine block clearance for stroke and con rod changes...it's quite a set of factors, and this is why it's all best left up to professional designers and engine builders.
You want to build a good hi HP normally aspirated Ecotec? Destroke it to 2.0 liters and rev that puppy! The parts exist, and it's a proven combo.
I could not have said it better! Turbo engines are easy and affordable to build, especially when compared against high-strung, high-RPM normally aspirated engines with big cams, valves, porting, etc.
Last edited by Hahn RaceCraft; 05-10-2008 at 06:24 PM. Reason: Automerged Doublepost
Old 05-10-2008, 06:24 PM
  #59
bridfi's Avatar
yeah, i really didnt like the idea of increasing stroke and shortening rods, due to the rod angles being so harsh on cylinder walls and wrist pins. i might just keep stroke and rod length factory and throw on a small turbo with low cr pistons. or go taller pistons.
thanks guys
Old 05-10-2008, 06:25 PM
  #60
bridfi's Avatar
i like the idea of better atomization and sweet sounding BOV, anyway...
Old 05-10-2008, 06:28 PM
  #61
RooTBeeR's Avatar
nice, another turbo 2.2 in SCE!
Old 05-10-2008, 06:39 PM
  #62
For street, yea I would say F/I is the way to go. A finicky high reving engine is fun at the track, but not something you want in a daily driven car.
My old Flathead is bored/stroked to 313cid, 10.1:1 CR, Edelbrock heads, full valve train w/ bigger valves, much more aggressive cams (They actually make power to 5.5k rpms! ), and a **** load of other minor tweaks. Specially on the oil and water pump. Of course, everything but the minor tweaks only cost me ~$3k in parts. Things are cheap for the flathead.
Old 05-10-2008, 09:12 PM
  #63
IonNinja's Avatar
man this thread was ******* confusing...
first people are saying rod length doesn't effect stroke at all...how so? I'm still not picturing how two different rod lengths give a piston the same amount of travel???
then on page 3, a guy comes in saying to get longer rods, shorter piston height...nothing about the crank and nobody says ****. lol
I need some clarification here...
Old 05-10-2008, 10:24 PM
  #64
RooTBeeR's Avatar
Ok, rod length doesn't effect your stroke except for where it sits in the cylinder.
i.e. longer rod will make the piston sit higher in the cylinder, shorter rods will make the piston lower in the cylinder.
Where as if you were to make the crank arms longer that would make the distance that the piston has to travel longer, hence a longer stroke.
http://auto.howstuffworks.com/engine1.htm
Old 05-11-2008, 01:07 AM
  #65
Witt's Avatar
The first part about rod length is correct, you can't change stroke by changing rod length. Its purely a function of the crank as others said.
What the guy was saying about the longer rods was to safely increase engine speed limits is to get longer rods and/or a shorter stroke, not the con rods are what actually are changing stroke. The shorter stroke will slow down piston speed and the longer rods will decrease the harsh angle at which they operate. He stated by changing rod length and piston pin height only, it will allow a higher engine speed as the angle of the con rod is different. This alone doesn't change stroke, but destroking also allows a higher engine speed which is why they go hand in hand.
Old 05-11-2008, 04:36 PM
  #66
tru2nrtt777's Avatar
I'm no expert either but some members here can probably explain it in a little better detail than me as a few design engines for a living.
I am no pro either but I have built a few engines in my time and you are exactly correct my good sir.
Originally Posted by hatrickstu
so=
increase rod length, typically increase compression, but has no effect on stroke. also, does this not allow you turn as many revs right?
stroke is purely determined through the crank?
Correct, these are the effects of changing sizes from stock:
Crank= stroke/rod angle/compression ratio
Piston= compression ratio
Rods= compression ratio/where along the cylinder walls the piston will move
Originally Posted by blissmaster13
My head hurts....I guess that's what I get for trying to keep up with experienced guys.
Haha, we all gotta start somewhere bro.
yeah f***in right.
You wont spend $500 for 10hp but you will spend $3000 for 50? What kind of sence does that make? Also the calculator is assuming everything else stays stock. If you have been dyno'd with everything else making 230 hp then it will be more like a 20 hp change when you up the CR.
You may need this too grasshopper:
http://www.wallaceracing.com/max-rpm2.php
Old 05-11-2008, 07:40 PM
  #67
bridfi's Avatar
how about this: im going to buy a SS/TC for another 10000 for that extra 110 hp.
and a turbo wouldnt give me 50, id shoot for 100.
Old 05-11-2008, 08:28 PM
  #68
RooTBeeR's Avatar
Even better, DO IT!
Old 05-11-2008, 08:44 PM
  #69
TVS_SS's Avatar
now we just need to throw in, valvetrain stability, flame speed, location of peak pressure, Pressure differentials across valves, and how cylinder head flow bench numbers at 28" dont really mean anything..
then we'll start to have a good conversation!
Changing one thing on an engine doesnt "increase power significantly" Proper engine design requires more tradeoffs than i care to discuss..
Old 05-11-2008, 09:18 PM
  #70
All very important points, but most likely beyond most people here.
Old 05-11-2008, 09:54 PM
  #71
^^^ I have to agree there. Most experienced engine builders I know(redneck backyard mechanics who run drags and dirt track) dont even understand a sentence in TVS_SS's post.
Old 05-11-2008, 10:00 PM
  #72
bridfi's Avatar
cool
but it was just a simple question. and i got my answer.
so /thread
ss/tc here i come
Old 05-11-2008, 10:18 PM
  #73
Hey bro, come on. If we end up having a discussion on the effects of varies changes to an engine, at the least it will proof informative to people who read it.
Old 05-12-2008, 06:49 AM
  #74
cool
so /thread
ss/tc here i come
Why not just buy MY car... and beat the SS/TC? AND save $8000.
Or go one step further... buy my car AND the Hahn 20g kit/TVS/ZZP Twincharge and beat EVERYTHING... Muhahahaha... (well, not EVERYTHING...)
https://www.cobaltss.net/forums/complete-cars-101/fs-usmcfieldmps-vic-red-ss-sc-110757/
Solaris99
28
03-15-2017 01:22 PM
HEATON
10-16-2015 07:21 PM
Stuff
10-01-2015 05:47 PM
OPCrer
09-27-2015 08:11 PM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: longer rods = higher rev?
