looking for supercharger parts
Eaton M62 supercharger
lsj manifold
Intake Manifold Endplate
lsj throttle body
Stock Heat Exchanger
intercooler pump
intercooler bracket
intake manifold bottom mount
lsj stock idler pulley
lsj stock tensioner
Stage 2 Belt, cut one rib off
3'' pulley
Alternator Bracket
LSJ Fuel Injector Wire Harness
LSJ Fuel Injectors (33lbs)
ž” I.D. Hose
coolant tank
MAP Sensors (located on Intake manifold and Supercharger)
Stock Filler Neck
lsj manifold
lsj throttle body
intercooler pump
intercooler bracket
lsj stock tensioner
3'' pulley
Alternator Bracket
ž” I.D. Hose
coolant tank
Stock Filler Neck
sorry didn't include this would be everyting
SS/SC oil pan, full SC set up, 60 pound injectors, full exhaust (header, cat-less down pipe, 3 inch cat back) intake and i am sure i am forgetting stuff
You don't have to have a SC oil pan or 60lbs or even really full exhaust. But yeah... they are nice additions.
2500... ****... I've been buying a bunch of new parts for this build...and 3 gauges, interceptor, boost, AEM wideband... ZZP triple gauge pillar, etc... powdercoating this and powdercoating that and I hit 2400, but that is with everything needed to start the vehicle..
P.S. Don't forget this includes gauges ($500 worth).... windshield wiper conversion parts ... and the LSJ DP and LSJ Header to remove SAI.
Purchased Supercharger Parts List
GM Parts
11900248 – LSJ TB To SC Bolts (4)
12575463 – LSJ TB Gasket
12584342 – LSJ Supercharger Gasket
12594387 – LSJ IC Pump Insulator
12597855 – LSJ Intake Manifold Gasket
12597993 – LSJ Stage 2 Serpentine Belt
12614973 – LSJ 1 Bar Map Sensor
15247280 – LSJ Upper Radiator Hose
9230949 – LSJ Exhaust Manifold Gasket
11516342 – LSJ Intake Manifold Mount To Block Bolts (2)
11589214 – LSJ Supercharger to Intake Manifold Bolts (4)
12345982 – Genuine GM Supercharger Oil (Qty 2) 4 oz ea)
12584369 – LSJ TB To Purge Solenoid Tube
12585150 – LSJ IC Pump Rear Bracket To Intake Manifold Mount
12586367 – LSJ IC Pump Front Bracket To Rear Bracket
12586632 – LSJ Lower Intake Manifold Mount
15226536 – LAP | L61 | L65 Coolant Reservoir
15075118 – LAP | L61 | L65 Coolant Reservoir Cap
15231157 – LSJ Downpipe To Cat Back Gasket
15235773 – LSJ Exhaust Manifold To Downpipe Gasket
15253932 – LSJ Power Brake Booster Vacuum Hose
22729469 – LSJ Windshield Washer Container
22732432 – LSJ Wiper Cowl To Washer Container Hose
88986255 – LSJ 8 Pin TB Connector (LAP | L61 Only 6)
89046833 – IC Pump Connector
90537953 – LSJ Exhaust Manifold Heat Shield
15411879 – 2005 Cavalier Injector Wiring Harness. No cutting needed using GM Stage 2 Injectors
New Parts
ZZP Heat Exchanger
ZZP Triple Gauge Pod
OTTP SS SC Pulley Bolts
Aeroforce Interceptor Gauge
GlowShift Vacuum | Boost Gauge
AEM Wideband Air | Fuel Ratio Gauge
OTTP 3.0 Polished Pulley (For Stage 2 Hub)
M-8501-L54 Ford Racing Intercooler Pump
NGK Copper Spark Plugs (Part# LFR6A-11)
Used Parts
Eaton M62 Supercharger
GM Stage 2 Injectors (42lbs)
Stock LSJ Air Intake
Stock LSJ Tensioner
Stock LSJ Downpipe
Stock LSJ Idler Pulley
Stock LSJ Throttle Body
Stock LSJ Serpentine Belt
Stock LSJ Intake Manifold
Stock LSJ Exhaust Manifold
Stock LSJ Alternator Bracket
Stock LSJ Supercharger Pulley
Standard Bolts Needed (Not GM)
LSJ 1 Bar MAP To Intake Manifold
M6 x 1.0 x 25 (Qty 1)
LSJ Intake Manifold Mount Bracket To Intake Manifold
M10 X 1.50 x 50 (Qty 1)
LSJ Rear IC Pump Bracket To Intake Manifold Mount
M8 X 1.25 X 25 – (Qty 2)
LSJ Front IC Pump Bracket To Rear IC Pump Bracket
M8 X 1.25 X 35 – (Qty 2)
LSJ Idler Pulley To Block
M10 X 1.50 x 75 (Qty 1)
LSJ Idler Pulley To Alternator Bracket
M8 x 1.25 x 25
LSJ Intake Manifold To Block
M6 x 1.0 X 75 (Qty 2)
LSJ Alternator Bracket To Block
M8 X 1.25 X 130 (Qty 3)
LSJ SC Bypass Valve To SC
M8 X 1.25 X 20 (Qty 2)
LSJ Tensioner Lower To Alternator Bracket
M8 x 1.25 x 35
LSJ Tensioner Upper To Alternator Bracket
M8 X 1.25 x 40… not standard bolt though. Has to be metric hex socket bolt.
