loudest exhaust possible!!!
#151
whats good about this cat?? can u give me pros and cons?? i want one that will be loud and not real restrictive but still gives me adequate back pressure
#153
#154
its definitely going to flow better than stock but its not a racing cat so it'll still give you some backpressure. do your own price research... check ebay, probably find one on there.. its probably around $150
#158
#161
#164
with every muffler or cat you remove your exhaust will get louder but will also sound more raspier...so, have fun with that.
#166
tell your friend to read up on backpressure, and he'll learn why it's bad. also, what is the point of totally freeing up the exhaust piping, and having the air running through a crazy restrictive cat? it doesn't make sense.
#168
get a v8 if you want something that will sound good with a loud exhuast. I bet within the first day you will hate yourself for doing it, then within a couple weeks you will be pulled over and ticketed
#169
okokok. i get it. y dont i just save some money. pick up a CA V1 header, xtc catless DP and a megan racing drift spec cat back...
that way it will be loud, not rice, and have noticable power gains.
#173
Originally Posted by jacobmprater View Post
im thinkin if i could use a glasspack as a resonator and a fart can as my muffler. would i have enough then???
enough said!!!
yelp that should be enough backpressure and still pretty loud.. Just remember that with no cat you will get a CEL..
Make sure that you use 2.5 exhaust pipe.. it gives a deeper tone.."sounds better"
The whole thing should not be to expensive either.. one time I picked up a glasspack from summitracing.com for under $30 ...and a stainless steel "fart can" off ebay for around $40
#174
I actually think the SLP Loudmouth II Catback Exhaust sounds pretty beefy, its a Dual pipe, and they claim to be the only "true" Dual pipe exhaust for the cobalt.
